My Current setup - Opinions?
Old May 16, 2007 | 04:29 PM
XBS's Avatar
XBS
Just wanted to share the current setup on my truck and see what the pros recommend/ thinkg Basically I want a safe setup with good power ( what everyone wants ) so if anyone thinks something isn't safe let me know.
2005 CTD 3500 Crew Cab LB SRW
3" Lift front 1" Rear, BFG 315/70/17 A/Ts
Magnaflow 5" Turbo back exhaust (LOUD)
Diablosport Predator/Powerpuck Stacking Bundle - on the Extreme setting
The truck is fast when I switch the puck the the highest setting, but doesn't do crazy burnouts like some guys on here say their trucks do.
I know I should get an EGT and Trans temp gauge, and that is in the works just trying to find the cheapest place to get the combo....
Ive been reading on "boost foolers" and I assume what they do is make the truck boost more, would it be safe to add one to my current stack?
I am thinking about doing an intake upgrade but don't know if its worth it and don't want to spend on a bunch of money on one either.
Let me know what you guys think, I will try to get some pictures soon!
-George
Old May 16, 2007 | 04:32 PM
XBS's Avatar
XBS
Also forgot to add what tranny upgrades can I do that aren't too expensive, I know the tranny is the weak link we you add this much power...
Thanks guys!
Old May 16, 2007 | 04:39 PM
Black SunShine 04's Avatar
Sounds like a pretty good setup you should take off that big old muffler and get yourself an airraid Jr. Kit and you'll be good. Gauges fo to dieselmanor.com they have good prices. Good luck.
Old May 16, 2007 | 04:44 PM
XBS's Avatar
XBS
Do you mean replace the Magnaflow muffler with an Airraid Jr. kit? Is that a quieter 5in muffler that flows the same or better?
Thanks!
abc4yew's Avatar
You need a laminated/billet flex plate, Good Torque Converter, modded valve body as a minimum. What are your current boost levels....you don't have a clue cause ya need a boost gauge also . Get the gauges first and stay off extreme until you do. I can do a burnout on Smarty SW1 with my tranny on a stock turbo. Oh yeah with an aggressive stack like you have a bigger turbo is a necessity. Once you get the gauges and tranny done get a boost fooler. ks
Old May 16, 2007 | 05:02 PM
XBS's Avatar
XBS
I am about 30psi ( what it shows on the programmers)
Where can I purchase the tranny upgrades or were to send the parts to get upgraded?
Also I don't want to do anything major like turbo, intercooler, etc. If I get to a point where I can get anymore power I will just stay happy with that
-George
Old May 16, 2007 | 05:12 PM
Sorry I didn't see that you already modified your exhaust.
Old May 16, 2007 | 09:45 PM
abc4yew's Avatar
If we all knew where you were we could help you out better. ks
mrod67
Feb 22, 2008 12:22 PM
ryanihf250
Jan 17, 2008 02:58 PM
Common
Mar 23, 2007 03:07 PM
dodgeboy59td
Feb 20, 2007 08:25 AM
n0ne
Sep 26, 2006 11:27 AM
