unpluging the map sensor?
Old Aug 31, 2005 | 03:44 PM
blackdiesel's Avatar
Registered
i had it suggested to me that if i wanted smoke off idle that i could unplug the map snesor wire off of my comp. he said that it threw a low voltage map code or somethin. Have any of yall done this? will the code go away when the map sensor is pluged back in? thanks
Old Aug 31, 2005 | 06:57 PM
Jetpilot's Avatar
If the voltage from the MAP is too low you will have a significant power loss..... The check engine light will illuminate but will reset itself after a few cycles.
Doug
Old Aug 31, 2005 | 07:49 PM
AAmeeting's Avatar
Judging from your sig you shouldnt need anything to help you make smoke
Old Aug 31, 2005 | 08:02 PM
Registered
haha yeah ur right. when im drivin jsut want some when i blip the accelerator in neutural. jsut for a pic or something.
Old Aug 31, 2005 | 10:51 PM
rebal's Avatar
you want smoke? plug a mad ecm in and you got it ...plus its tons faster
Old Sep 1, 2005 | 07:23 AM
Registered
how much is one of those with out timing for a ho 02?
Old Sep 1, 2005 | 08:01 AM
White00's Avatar
The Mad is around 500, plus the core which varies opon who you order from. It is usually about 400 I believe. The mad is well worth the money and will make all the smoke you want! I have stock injectors and it will put out a very nice cloud just punching in neutral. With your injectors you have you should be able to fog out a whole 4 lane!
Old Sep 1, 2005 | 08:05 AM
Registered
ahhhh a whole four lane... sounds awesome! how much horsepower and torque does one give ya? if i get one of thoes ill probley have to get the dd from southbend.
Old Sep 1, 2005 | 08:36 AM
Registered
im going to have to upgrade my turbo sometime. since i have the turbo mounted exhaust brake, is my only option a 40/35 hybrid? will that be enough? what would be the turbo of choice with my set up + a catcher?
Old Sep 1, 2005 | 09:32 PM
Ocmechanx's Avatar
I would definitaly go bigger b1 or sumthin to that effect ht2b sw300 ect
I've got a 35/40 hybrid and w/my setup (wastegate unhooked I can push 48-53lb boost........too much, way too much
I probly have made a mistake and went ahead and got(in the prosses that is) the mad, and I'm just gonna try a 16cm2 housin on the 35/40 and hope it'll hold together,..........headgasket is startin to worry me now too now that I think about it
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
