Surging when cold with Mach 3's.
Old Aug 9, 2005 | 09:50 PM
torqueman's Avatar
Anyone else experience surging and sometimes it will actually stall when I put it in gear.I hear alot of good about Mach 4's Maybe Don M. can upgrade me to 4's.One thing I also noticed with the 3's that motor sure is alot louder.You when motor is cold its usually louder,Now seems to just stay that loud even when warm.Maybe Don M. you might have some suggestions or anyone else.......Thanks Mark By the way I have DTT auto and just shy of 500 hp to the wheels if that helps....
Old Aug 10, 2005 | 01:34 AM
dodgediesel4x4's Avatar
Has this happened since the install of the 3's? Does it do it all the time? have you ever had them pop tested? How much air do you have to go w/ the high fueling of the 3's? Let us know what else you have (fill in signature).
Old Aug 10, 2005 | 08:46 AM
HOHN's Avatar
Part of this is somewhat normal for a bigger injector-- but not completely.
What happens is that the high flow of the injector cause a shorter, more intense combustion event--> Higher peak pressure and thus, more noise.
However, stalling when you put it in gear should not happen just with an injector swap. I'd be looking at other causes for the condition.
Old Aug 11, 2005 | 07:53 PM
torqueman's Avatar
Thanks guys for the replies.I'm running B1-2 with my setup.I heard the 4's are actually a quieter injector than the 3's.I also get slower starts when warm, but I figure that might have something to do with my 28 psi at idle.I run carter pusher with stock lift and Ray's banjo's.At wot I'd be lucky to get it down to 15 psi.Hohn how do you like the 4's.I've changed vp once with Pier's .028 spec pump already about year and a half ago.Sure hope it's not going again didn't throw no codes at all.I guess the truck did start surging after the inj. install but nowhere near as bad as now and not stalling.Thanks Mark.......
Old Aug 11, 2005 | 08:12 PM
PourinDiesel's Avatar
Maybe higher pop off pressures are causing the stall in combination with a tight converter.
Anything is possible.
Old Aug 11, 2005 | 08:36 PM
oscaroc's Avatar
Since installing Mach 4's I get the loping at idle(when cold) as well but no stalling. Warmed up the they are quiter and my idle dropped a bit acceleration seems smoother as well.
Old Aug 11, 2005 | 09:50 PM
torqueman's Avatar
Thanks for the replies guys.It sure seems to me that the mach 4's are a much better inj. than the 3's. I've even read guy's getting better milage than the 3's.Maybe Don M can do something with my 3's for a set of 4's.Thanks Mark......
Old Aug 12, 2005 | 10:10 AM
Augusta's Avatar
Stalling when put into gear.
I used to have a similar problem.
See this thread and my reply...
Might be worth a try.
Augusta
Old Aug 13, 2005 | 02:07 PM
torqueman's Avatar
Thanks Augusta I'll give it a try.I was the same way,when I first got my truck I figured it was idling to high so I backed off screw but it never took the idle down.I don't think I ever adjusted the screw back so maybe I'll play a little.I was also told the fast idle tsb might cure it but I just hate going to dealer.Thanks.......
Old Sep 1, 2005 | 10:01 PM
torqueman's Avatar
Hey Augusta,I turned the torx screw in a little and it seems like it might have solved my problem.It hasn't stalled on me yet.Thanks alot for the info sure saved me alot of bull.It's little things like this that makes me like this site so much.Thanks Mark........
RonA
14
Sep 4, 2007 11:09 AM
cutlass
Oct 15, 2005 12:48 PM
APD
Mar 3, 2005 05:39 PM
sway825
Dec 8, 2004 10:21 PM
ChrisM55
Oct 19, 2004 02:56 AM
