surging on start up when cold
Old Oct 12, 2005 | 11:04 PM
cutlass's Avatar
I have a 2000 2500 auto that has started surging on start up when cold.
I have no mods to my engine and no codes being thrown. Any ideas?
Old Oct 13, 2005 | 05:52 AM
crobtex's Avatar
I would start with checking the fuel filter and for any other fuel restrictions. The best way to tell is to hook a fuel pressure gage to it.
Old Oct 13, 2005 | 08:16 AM
Dr. Evil's Avatar
Is this your first diesel?
What kind of surge? The entire truck or just the voltage??
Old Oct 13, 2005 | 08:24 AM
P.J's Avatar
P.J
Good point, cause mine will start that kind of thing this time of year.
Voltage spike due to the grid heaters, right?
Old Oct 13, 2005 | 08:34 AM
Dr. Evil's Avatar
You are correct sir...
Old Oct 13, 2005 | 08:37 AM
Mopar1973man's Avatar
It that time of the year again... The grid heaters pop on. (Unless you plugging in the block heater in!)
If you have a weak LP already and the grid heat comes on it might be robbing the VP44 of good fuel pressure... Check your filter too...
Old Oct 13, 2005 | 09:14 AM
cutlass's Avatar
Sorry I should have been more specific. I have owned the truck for 3 years and am firmiliar with the grid heaters and also change fuel filters every second oil change (new fuel filter every 20,000km). This is more of a romp in the idle when the truck is at idle when cold. Truck has 250,000km on it and has a 1 year old VP-44 and lift pump. This just started about a month ago with no other problems.
Old Oct 13, 2005 | 09:20 AM
P.J's Avatar
P.J
Time for me to do my best Ed impression, HA!
Back to topic though, my truck will "surge" per se in very low temps (for me that's less than 20*) but only for about 10 seconds. It's almost like, it's sputtering and choking on the fuel. I assume that is normal and never gave me a worry. With normal FP I would say your okay.
Old Oct 13, 2005 | 01:04 PM
cutlass's Avatar
Temps for me are not low yet I guess what bothers me is it never did it before. I will try another fuel filter and check my fuel pressure. You never know. I have not changed the injectors yet when should they be changed?
I do use an injector cleaner/lubricant in every tank.
Old Oct 15, 2005 | 11:09 AM
loid mongol's Avatar
When my lift and injection pump were going bad my engine would surge at startup. kinda like ..... rrrrrrrrrrRRRRRRRRRRRRRRRRRRRRRRrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrRRRRRRRRRRRRRRRRRRRRrrrrrrrrrrrrrrrrr rrr LOL.
Hope that's not your problem.
Old Oct 15, 2005 | 12:48 PM
cutlass's Avatar
Loid, with the luck I have had with this truck it would not surprise me.
cougar
Oct 7, 2011 12:03 PM
bullfrog5.9
Jan 3, 2010 05:41 PM
torqueman
Sep 1, 2005 10:01 PM
APD
Mar 3, 2005 05:39 PM
ChrisM55
Oct 19, 2004 02:56 AM
