Twins Parts List?
Twins Parts List?
If I have an HT3B and an HX35W, what else will I need to assemble a set of twins for a 96 automatic truck? Thanks for the information.
Lets see you will need the material to make the hotpipe. Which is a schedule 40 3"elbow, a t-5 flange for the ht3b, and either the plate that bolts right on to the 35 or the flange that clamps on. You will need an oil feed line and drain for the htb3. You may need a new feed line for the 35 as well. You might want to consider an external gate for the htb3 as well. The cold pipe depends on what size tubing you want to use. On my twins I used two 4" 90s and one 3.5" 90 with an adapter from 3.5" to 4". On the pipe to the intercooler I think it is two 3" 45s. You will also need an air filter and some 5" tubing for the intake. A bottom turbo support bracket is a good idea. Since your truck is an auto you will need material to move the heat exchanger. I can't think of anything else right now, but I am sure I am forgetting something. Others will chime in I am sure.
Joe
Joe
I have the ability to do all the welding and fabricate the flanges and adapters if needed as we have a full machine shop. I can also make my own oil lines as long as I have the fittings which I should be able to make or find easily. The only thing I will need to buy is the HT3B which I have a good lead on, the piping for the hot and cold pipes and the external wastegate. Will probably have to get another boost gauge as I have read on here. As with all mods there are unexpected costs and then the aftermath like blown head gaskets and transmissions. I would like to buy an extra manifold and do all the fabrication off the truck until complete and then install once complete. The downpipe will have to change and then? Thanks for the input.
Joe
I appreciate it. I dont need twins either but, If I can do them on the "cheap" (relative) then I would love to have a set. If things dont go well after they are built then I can always sell them and get another single.
Mine ended up running me right around $1100 but that was with buying a new k31. A regular s400 would be about $200-300 cheaper. Now this is with me not having to but any flanges only tubing. I hope this gives you a rough idea.
Joe
Joe
Thanks, so probably 1500 or so is the cheapest it could be done. Cyric, does spoolup with the K31 and stocker compare to just the stock turbo, assuming you had the same fuel enhancements prior to twins.
Joe
Now do you think that an s 300 turbo instead of the stock HX 35 will spool faster than your old Super 40? Or do you think it would be more of a racing setup?
Joe
S400
Cruising around the web and came across this place. http://dallasturbo.com/specials1.html They have S400 and k31 on special. Are these products sized right for twins? Good price?
Alan
Alan
dodgediesel
17
04-05-2011 11:21 AM
Stock 02
28
09-24-2006 11:09 AM
CTD_Neil
07-19-2005 08:13 PM
