Turbos - Comparing Numbers
Old May 14, 2005 | 11:14 AM
  #31
ramtd02's Avatar
HY-35
Altitude: 2200'
60mph@ 3psi
70mph@ 5psi
WOT@32psi (30-115mph) = 1025*
Air temp = 55*
Old May 14, 2005 | 12:32 PM
  #32
Don M's Avatar
DTR Advertiser
Super Turbo:
60 MPH 0 boost @ cruise speeds and throttle position /EGT = 950
70 MPH 0 boost @ cruise speeds and throttle position /EGT = 1000
WOT @ 73 PSI = 2000 plus EGT
Obviously I need a wastegate for ths thing. LOL
Don~
Old May 14, 2005 | 01:07 PM
  #33
duke1n's Avatar
All you guys are screwing up by running WOT and not WFO. There is a difference!
Old May 14, 2005 | 01:41 PM
  #34
got...DIESEL?'s Avatar
see the sig for mods......sea level, avg 50* air, 50%-70% humidity flat ground everywhere.
60 mph.....5 lbs.....650* in OD locked.......10 lbs....500* in 3rd locked
70 mph.....8 lbs.....700* in OD locked.......15 lbs....550* in 3rd locked
at maximum 36 lbs high gear locked
70 mph.....1000*
80 mph.....1150*
90 mph.....1300*
100mph....1400*
110mph....too toasty for me and choppin' the throttle
I found I had to nearly let the wastegate function as stock just to keep the pressures below redline, as the 3 non-gated cylinders could nearly drive this turbo on their own. A ventilated turbine hsg, ext WG, BOV and a big twin are within my grasp and awaiting mock-up. Then the fueling will start.
dditt0635004x4
13
Feb 7, 2007 12:36 PM
miketriton
Apr 22, 2005 01:14 PM
TE-44
Apr 28, 2004 03:21 PM
1320
30
May 31, 2003 01:01 AM
