Turbos - Comparing Numbers
Old Apr 20, 2005 | 08:19 PM
mooseman's Avatar
Originally posted by rjohnson
Thanks for posting.
Is that a 12 cm2 housing on your HTBG?
RJ
Sorry, Its a 14wg.
mooseman
Old Apr 20, 2005 | 08:24 PM
mooseman's Avatar
[QUOTE]Originally posted by CTD_Neil
Moose, can you tell me what your EGT's were when you dyno'd?? I am looking at the HTBG or HTB2 for my next turbo. thanks [/Q
Here ya go. Hope this helps you out.
2001 Dodge cummins, AUTO, 125 horse jammer injectors, EDGE DRAG COMP, HTBG TURBO, scotty II AIR INTAKE, 35" bfg all terrains
EDGE DRAG COMP HP TQ MAX EGT MAX BOOST PSI
STAGE 1 366- 844- 1200- 35
STAGE 3 429- 945- 1400- 38
STAGE 5 453- 1057- 1600 +- 42
1/4 mile was run in stage 3 @ 14.303 sec. and 92.761.UOTE]
Old Apr 20, 2005 | 09:24 PM
CTD_Neil's Avatar
Wow 1600? Thats crazy. I was worried when I hit 1400 this last weekend on the dyno. I'm going to need a bigger turbo i guess. I will have the same combo as you pretty much, except 115 HP injectors. Will an HTB2 be enough to keep it below 1400?
Old Apr 20, 2005 | 10:23 PM
John_P's Avatar
rjohnson:
Good post buddy!
Here is the data from my 2002 Dodge CTD:
Altitude: Sea Level
Turbo: Piers HX-40/16
60 MPH: 5-6 lbs.
70 MPH: 7-8 lbs.
EGT@ 30lbs: 1050
John_P
Old Apr 20, 2005 | 11:44 PM
Beast2B's Avatar
don't forget to factor in a wastegate when the temps start to climb excessively. rjohnson actually gained some hp by LOWERING the max boost (51psi down to 45psi, right?). also, the turbo and injector combination is crucial, too much fuel or not enough can get you running hot EGTs
Old Apr 21, 2005 | 05:41 PM
Paul Winey's Avatar
Smile
Great thread! Not to complicate things but timing, gearing and tire size will play in some too. Unlike you guys with 3.55's my speedometer stops eventually . Here are mine with an HTB2, 12cm/62 mm wheel, 4" exhaust, 191 DV's, 370 injectors, #100 plate, 17.5 timing and pump tuned at 500' altitude.
60 mph: 4 psi, 575 EGT
70 mph: 7 psi, 675 EGT
30 psi uphill pull 875 - 900 EGT (speedo 80 mph - did I say 80 officer, I meant 55)
Now if I drop the hammer it climbs fast until I let off (maybe I should take the snow plow off now that Spring is here )
Paul
Old Apr 21, 2005 | 05:50 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
Potentially those testing thier setups could hold the brake pedal while driving down the road load the engine up to 30 psi and hold it for 4-8 seconds not hard but hard enough to maintain 30 psi steady then its just load against the engine not tire or gearing related right??
Old Apr 22, 2005 | 08:46 AM
sleds's Avatar
Sledpuller66
altitude 4500ft.
60mph 0psi 550F
70mph 4psi 650F
30psi 950F
Old Apr 22, 2005 | 08:55 AM
Forrest Nearing's Avatar
1600* is nothing
just don't keep it there too long
Forrest
Old Apr 22, 2005 | 09:26 AM
RowJ's Avatar
The great thing about looking at these numbers, IMO, is that Max HP doesn't matter...cause were not using it. The biggest variable will be drag, I think. Larger tires, flat beds, grill guards, different empty Wt., etc. will affect the results a little.
Paul Winey brings up a good point...I'm not sure if gear ratios will have a big effect on this set of #'s or not? I don't see a difference in my truck....boost at 60 & 70 are the same in 3rd as in OD. But still....
RJ
Old Apr 24, 2005 | 10:20 PM
gandrews's Avatar
elevation 500 to 1000ft.
Air temp 55 to 60
Pulling a trailer with a small tractor - around 7500lbs
MPH = 60
PSI = 10
EGT = 800
Pulling a 6 to 7% grade
MPH = 55
PSI = 30+
EGT = 1050
Same elevation and air temp but without the trailer
MPH = 65
psi = 4 to 6
EGT = 550 to 650
Trying to hold 30psi is difficult without the grade and without the trailer -
MPH = speed limit + a little
PSI = 30
EGT = 1050
The truck profile is current. on edit Note this is pre MAD ECM
George
Old Apr 27, 2005 | 12:36 PM
Beast2B's Avatar
well it took a while to get on the highway... it's great working downtown with a six-speed...
B1-2 turbo, EDM3s, MadECM, Drag Comp on 2x5
elevation: 200'
temp: 70*
60mph: 3-4psi
70mph: 6-7psi
30psi boost (besides way too fast!): 1050-1100*
Old Apr 27, 2005 | 12:49 PM
RowJ's Avatar
Thanks Galen
I imagine it can be tricky getting stable reading in populated or hilly areas.
I'm suprised that your numbers are so similar to my KSB-1??
RJ
Old Apr 27, 2005 | 05:16 PM
Beast2B's Avatar
it was a little bit of guessing/speculation. my 60psi gauge doesn't read under 5psi, so it was just bouncing a TINY bit at 60mph, bouncing between 6-7 at 70mph. as i mentioned, that was in 5th (direct), but 3.54 and 37" tires gives me an effective ratio of 3.0 (relative to stock 265s)
i guess the main reason it took me a while is the PRICE OF FUEL!! it finally hit me at $2.50/gal. i actually have cut down on my driving specifically because of the cost of fuel. increases previously have ticked me off, but now i don't drive unless i have to.
i think we just have too many variables to get very precise comparisons. same day/same dyno or same trailer/same hill might be better if it could be arranged...
Old Apr 28, 2005 | 07:19 AM
Mopar1973man's Avatar
You guys might want to add in the air temperatures too... As the weather warms and cools I've seen my pyro react it the in the same manner. It can vary about +/-100*F on the same road at the same speed (cruise set)... But the temps outside temp were 40*F are now 75*F... It makes a big difference in these numbers...
