turbo housing question
Old Sep 20, 2007 | 09:40 PM
jd4440's Avatar
I found this item on ebay and i have a s300s off of a john deere tractor it has a it has 16 cm housing so it spools to slow i think it has a 57cm inducer so i guess i probley should not buy it just wondering if any one knows if this would fit for sure
You are bidding on a used in great condition HTT 65mm 12cm exhaust housing off a Street Stock 62 turbo. It does not have the actuator but would make a great swap on any S300 style turbo with a 65mm inducer wheel. If you have a 14cm housing and want to try a 12cm heres your chance. HX40 style outlet for 94-02 Dodge.
Old Sep 20, 2007 | 09:50 PM
Rods's Avatar
I would guess that the 65 is the exducer , so if you could take your housing off and and measure yours to see if its the same it would work but you also need to make sure the trim is the same (inducer) and clamping style
ajbirken
Sep 6, 2006 12:11 AM
95black2615
Jul 21, 2005 09:06 PM
Haulin_in_Dixie
Apr 13, 2005 06:33 PM
j
Jan 9, 2004 08:19 AM
HOHN
Dec 7, 2003 02:07 PM
