Turbo Help
Old May 19, 2005 | 04:50 PM
cep4982's Avatar
Turbo Help
Turbo went out in the Dodge. Its a 215 pump with no plate and it would get hot when i towed. I was looking at Htt stage 3, is there something else to consider?
Thanks
Kroner
Old May 19, 2005 | 04:54 PM
cep4982's Avatar
I forgot im plannin to get 370s in a few weeks.
Old May 20, 2005 | 02:55 PM
You could try the Stage III hybrid (they also have a Stage IV that's a 62mm wheel), but with the 370's and towing it's still gonna be too hot. I'd suggest stepping up to an HX-40 or their HTB2.
Old May 20, 2005 | 09:10 PM
Mcdowra's Avatar
Have you thought about the 300hp injectors?
Old May 21, 2005 | 07:56 PM
got...DIESEL?'s Avatar
300 will be just as hot as the 370's, just a little less smoke. The super 40 is a good midrange I hear......me? I'm building twins
Fill out your sig, everyone can help more if your truck is profiled.....welcome aboard
Old May 23, 2005 | 07:44 AM
bwat4's Avatar
I have the stage III along with 85 HP injectors. The stage III did cool an additional 200 degrees. With an EZ, 85 HP injectors and Scotty II it would not get over 1250 in hard pull. I would still go with a larger turbo, HTBG, HTB2, B1, HX40 or something comparable.
Brad
Old May 23, 2005 | 11:44 PM
dodgeman01's Avatar
J.R Adkins builds a sweet little switzer turbo thats great for up to 450HP.
I would call him if you still looking around to find out a little more before you plop down you hard earned money.
317 281 3130.
DM01
Old May 23, 2005 | 11:54 PM
WildBill's Avatar
IMO don't put the 370's in - wrong spray pattern, lots of smoke and heat. I put DDP stage IV's in my truck and they work sweet. On the other hand, maybe I don't want anyone else to have a clean running 12v with this much power
CumminsRedneck
Jul 6, 2013 03:20 PM
Ada381
Feb 10, 2008 07:58 AM
smalltownTPull
Aug 26, 2004 10:55 PM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
