turbo boost questions
Yes, you should have more boost than that if you're at the highest Juice power setting.
You should be able to exceed 30psi.
Check for boost leaks.
Did you install the boost elbow that came with the Juice?
I could only get 30 psi with the Juice when I first installed it. Utah has thin air for sure!
I eventually found a couple of small boost leaks and was then able to hit 32-33 on a good hill WOT.
I'd go through and tighten up all the t-clamps and spray a little soapy water around the air horn and intake manifold with the engine running and look for bubbles.
I'm usin the Edge boost gauge and the most i've seen on setting #2 is 18, could this be a MAP sensor issue? I've read they get diry and hinder performance and mileage. I did noy install the elbow on mine as it wouldn't go on an 02 auto truck. I'll check teh boost in the morning on setting #5 and see what I can get out of it? I usually drive on #1 as it's my DD and I'm always lookin for better MPG's but want the power for towing my junk in my avatar.
97dodgeram2500
Nov 1, 2009 11:51 PM
jcarrillo
Jul 10, 2009 08:24 PM
vwjunkie53
19
Nov 9, 2007 02:27 PM
gman07
Apr 15, 2006 08:32 PM
Bobcat698
18
Oct 22, 2005 12:27 PM
