TST Question 02 to 99?
Old Feb 12, 2007 | 05:54 PM
blackdiesel's Avatar
Registered
i know they make different adapters, but can you take a 02 tst and put it on a 99 with the right adapter? i herd that the edge comp wont mix, the map sensor voltage is different?!
Old Feb 12, 2007 | 10:05 PM
Registered
fellas! need help
Old Feb 12, 2007 | 10:12 PM
Djasik's Avatar
Well if you found the adapters, I believe there out there it would work. I thought my comp was acting up so me and my buddy switched comp boxes at the plugs. His still ran the same and so did mine.
Old Feb 12, 2007 | 10:14 PM
AggieJustin's Avatar
Since the TST is driven by boost readings from the MAP sensor, I doubt you can put a '02 TST on a '99. With the values read from the sensor being different, the TST wouldn't know how to apply fuel.
Old Feb 12, 2007 | 10:15 PM
B.A.Ram's Avatar
hence it should go on my 01.5...
Old Feb 12, 2007 | 10:39 PM
phox_mulder's Avatar
I believe its 98.5-99, then they changed voltages for 2000-2002.
(might be 98.5-2000 then the voltages changed)
phox
Old Feb 12, 2007 | 11:15 PM
Based on the Edge changes (and the TST instructions), I believe that 98.5-2000 are the same, then 2001 and 2002 had the new voltage.
Old Feb 12, 2007 | 11:16 PM
Registered
figures....
ill call tst tomorrow just to make sure
mjpalmer
May 19, 2005 11:34 AM
WhiteSport600
Dec 23, 2004 09:59 AM
BCobb
Jul 11, 2004 01:49 PM
Zino
Aug 15, 2003 10:14 PM
