truck wont start after comp install
Old Nov 1, 2006 | 07:00 PM
natlchamp2k4's Avatar
just put my comp in, its got power and the truck wont start. I used the remote wire from my cd player to get power to the box.
Any thoughts, what do people usually do wrong? Even if the wire isnt tapped good it should still start right.
thanks,
Jamie
Old Nov 1, 2006 | 07:03 PM
BigBlue's Avatar
I'd try and retap the wire (although it shouldn't matter but you never know), move the remote wire to a different source (I like the radio fuse in the fuse block), move the ground, and check and recheck all of your connections. Also check to see if you accidentally bumped something while you were running wires and what not.
Old Nov 1, 2006 | 07:09 PM
Aight, I forgot to mention that right before i put the comp in, i was running a smarty from caleb c. and just went back to stock sw. I didnt start the truck after I removed sw 9. everything went fine I thought, the smarty didnt do anything wierd.
Old Nov 1, 2006 | 07:10 PM
BigBlue's Avatar
Might wanna get the smarty back and see what it says. It might not have finished programming or something.
Old Nov 1, 2006 | 07:19 PM
Yeah im gonna reload sw 8 and see what happens, if it runs, i may re laod the stock sw again.
My stock clutch really doesnt need the smarty drag comp stack.
Old Nov 1, 2006 | 07:28 PM
BigBlue's Avatar
You should try the combo in my sig on a stock auto.
Old Nov 1, 2006 | 07:35 PM
BB I give you my deepest regrets............................The idiot in me came out, its actually relieving cause its nothing major. No matter what I try or what smarty sw is programmed, if that harness that goes into the back of the IP isnt plugged in, that truck will not start....................but when you plug it back in it will start
Sorry to waste your time Blue.
Thanks,
Jamie
The official website idiot
Old Nov 1, 2006 | 07:37 PM
BigBlue's Avatar
It's cool. We've all made mistakes. Like forgetting to tighten the fuel lines on the injection pump after swapping injectors and sitting there cranking for 20 mins before someone pointed out what you had done.
Old Nov 1, 2006 | 09:08 PM
caleb c.'s Avatar
Jamie, I totally forgot we had an athletic banquet deal tonight, sorry I didnt make it. Plug that smarty back in and see what she does!
Old Nov 1, 2006 | 11:51 PM
dude, caleb I finally got er all put back together and let me tell you, I was impressed. I can slip it in 4th and 5th with the box on kill. If I turn it down to level 4 I can stay in it, EGT's arent too bad as long as im not in it for 30-45 sec.
Overall very impressed, and yes, that box makes real smooth power. And no smarty right now.
Jamie
Old Nov 2, 2006 | 12:07 AM
Ph4tty's Avatar
Don't throw that around so loosely now.
It took me six months to connect three wires- beat that
Old Nov 2, 2006 | 12:18 AM
DodgeCowboy's Avatar
DTR's Cow Boss
i lost one of the sealing washers on the inlet side of the lift pump while putting the new lift pump in and did not notice tell i started getting hard starts and then it would not run as i limped in to the shop i noticed the washer on the ground put it on and tada new truck
Billwie
Oct 5, 2008 06:24 PM
bcool
Jul 21, 2008 06:32 PM
90dodge
Apr 8, 2007 07:06 PM
qcstunter
Jan 9, 2007 04:10 PM
txdodge97
May 20, 2006 07:11 PM
