transmission removal
Old Mar 29, 2008 | 07:03 PM
kelownadiesel's Avatar
Im reading in my hanes manual to take the tc cover off to get to the bolts that link the converter to the flexplate.I took that little cover with the 3 8mm bolts off and there seems to be no way to get to the bolts .Am I missing something or what? 47re 4x4.Maybe the instruction are generic and apply to gas motors only ,I dont know.Help me.Do you maybe have to remove the case bolts and slide it back?
Old Mar 29, 2008 | 07:11 PM
Mcmopar's Avatar
On the passenger side of the truck, under the tranny oil cooler is a "block plate" held on with 2 10mm bolts, remove that and you can get to the TC bolts, then remove the plastic "plug" just below that so you can insert your barring tool.
Old Mar 29, 2008 | 07:18 PM
Excellent thanks dude.You can just rotate the alternator to turn it though as well i thought.
Old Mar 29, 2008 | 08:23 PM
well that sucks ,those bolts are so tight in there i stripped both of them and still cant budge them with a vise grip .*** they arent reverse threads are they?
Old Mar 29, 2008 | 08:27 PM
Mcmopar's Avatar
Yes, but that will require two people, one to turn the alt. nut and one to watch the alignment mark at the bottom of the bell housing. If you did not know, there is a little mark in the bottom of the bell housing. Once the sheild is removed look into the opening, on the inside bottom, there is a little "arrow" that you line up with the bolt lug on the TC, this will put one of the other lug/bolt into the window where youjust remove the plate, so you can get your socket onto the bolt. I have probably confused you, but get a good light and check it out, you will figure it out.
Old Mar 29, 2008 | 08:29 PM
Mcmopar's Avatar
Nope, regular threads, get a 10mm 6 point socket.
Old Mar 29, 2008 | 09:13 PM
AlanF's Avatar
TC bolts
I didn't use a barring tool to rotate the crank although it would make the job easier. I am sure I put a socket on the pulley end of the crank. I could see the TC bolts through the access hole as I rotated the crank. Good luck with your removal!
Alan
Old Mar 29, 2008 | 09:18 PM
I cant budge either of those bolts ,they are so stripped it isnt even funny.I know what you mean about the bolts lining up I think.You can see where they mount when you take the lower cover off.I cant believe these bolts up above the barring plug,this is rediculous.Im ready to quit,let dtt do it,light the truck on fire or cut the heads off with the plasma.i guess Im gonna take the cooler off above so i can get a better hold of them.Thanks Mcmopar
Old Mar 29, 2008 | 10:19 PM
yep they are screwed now,thinking of cutting the heads off and tacking the plate on after,but the case is aluminum .2 little bolts cause so much trouble.
Old Mar 30, 2008 | 06:30 AM
Mcmopar's Avatar
Your welcome, you might be able to drill them out once the cooler is removed.
Old Mar 31, 2008 | 04:06 AM
LanceD's Avatar
I had a hard time with those bolts too, I had to tap them with a hammer a few times to loosten them up.
and to turn the engine over I simply used a pry bar on the teeth of the flywheel through the acess cover on the bottom.
Old Mar 31, 2008 | 08:08 AM
WVAussie's Avatar
Grind the heads off with a die grinder. Once the trannys out its easy to remove the adapter and drill and tap new threads.
Old Mar 31, 2008 | 03:24 PM
Fred Swanson's Avatar
The 2 bolts can be a real pain.
Old Apr 1, 2008 | 12:50 AM
good to hear guys,thanks I just may cut those off,plus i have a plasma machine anyways.i knew i wasnt the first guy to deal with those bolts being a pain in the ****,should be easy to drill them like aussie said.Anyways guys thanks alot ,but im using a hanes manual ,which is very generic.What are the steps to follow once youve got the starter and driveshafts out?the t case next then take off the tc to flexplate bolts?
Old Apr 1, 2008 | 07:47 AM
91rangerturbo's Avatar
Check this thread out. BTW the search function is very helpful here.
https://www.dieseltruckresource.com/...ission+removal
HUNTINNUT
Jul 27, 2013 11:40 AM
trik396
Jun 1, 2008 07:04 PM
ditchdigger
Apr 20, 2007 09:12 PM
Jambbii
May 31, 2006 04:33 PM
RoostrRiz
Jan 14, 2005 11:05 PM
