trans temp gauge
Old Mar 17, 2003 | 11:55 AM
apc's Avatar
apc
trans temp gauge
Trans temp gauge on order from Genos , Which line should I install in (i have acess to brass compression fittings) or<br>is there a port in the trans for pressure that can be used for temp. sensor
Old Mar 17, 2003 | 12:46 PM
Jrr's Avatar
Jrr
Re:trans temp gauge
The best way is to get a line for a 95 0r 94 that has a fitting already installed, but the line you want is the one that comes down from the heat exchanger behind and below turbo and crosses over to drivers side and goes to the oil cooler on drivers side front left of radiator.
1985cucv
Feb 18, 2010 02:03 PM
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
