trans and HP question
Old Jun 10, 2005 | 05:51 AM
shoe's Avatar
My question is do I need the tripple disc TC with my HP level or can I safely run a single with billet cover. All I want to add is some big injectors and be able to run the comp at 5.5 safely. my current mods are in my signiture. what do you all think?
Rob
Old Jun 10, 2005 | 09:08 AM
chasd60's Avatar
Dave Goerend told me up to 350HP with just a triple disc or with a single disc and an upgraded VB. Anything more than 350HP, he recommended the triple disc with a VB upgrade.
Old Jun 10, 2005 | 09:57 AM
Big Deezul's Avatar
I would say you would be really hurting a single with that set up...and if you tow something....forget about it
Old Jun 10, 2005 | 10:50 AM
Rrloren's Avatar
Sure makes a difference if you tow. I was OK for 3 months with a HD convertor with my sig. Towing 11m lbs toasted it , now I have the Goerends triple. Dave said I should be OK with this setup. I would mention that when my convertor went south it gave no warning, that I recognized , it just would'nt go anymore.
Old Jun 10, 2005 | 02:42 PM
lil jim's Avatar
Go ahead and get a trans., no one ever stops bombing once they start. A year ago I was just gonna tweak the pump.
Old Jun 10, 2005 | 08:56 PM
Huff nPuff's Avatar
Re: trans and HP question
Rob
I use the DTT single,Ive been at every power level from 400HP to over 600Hp I tow loads under 3000lbs I plow and drag race often.Ive broken lots of tranny parts e.g output shafts flexplates but Ive never had a converter failure.
nvr-enuf
May 10, 2011 02:49 PM
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
