trans
Old Apr 14, 2008 | 10:45 PM
dodge_24's Avatar
trans
i have a 01 with auto trans when is a good time to change the transmission oil and filter
s&b intake banks big hoss tuner, gauges,straight pipe
Old Apr 14, 2008 | 10:52 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Every 30k with light to normal use. Less when used for a lot of towing. Or, does the fluid look dirty? Does it smell burnt?
Or is it every 20k???? Know I'm not sure. I do mine quite often because of all the towing and the dirty environment I work in every day.
Old Apr 14, 2008 | 11:36 PM
dodge_24's Avatar
just highway use and fluid looks good just that ive heard u should change it at 100k
does the raptor work good?
i have the intank pump but would like to add another to help the intank pump for more flow just don't know what liftpump to use
Old Apr 15, 2008 | 02:45 AM
dozer12216's Avatar
If you know it has ATF+4 and is still red, it"s O'K. +4 does it's job until changes from reddish to brownish. So change it before it turns color. The oil manufactures would love for you to change it like motor oil.
Old Apr 15, 2008 | 04:51 AM
wurkenman's Avatar
Go up to almost the top of the page and click on user cp. Then fill in your signature, This way you do not have to type your mods every time you post.
Old Apr 15, 2008 | 08:50 AM
CODODGE2500MAN's Avatar
...then click edit signature on the left side of the page.....
Old Apr 15, 2008 | 08:29 PM
dodge_24's Avatar
thanks guys
Les Eid
Feb 13, 2008 09:22 AM
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
