Tranny oil cooler removal for twins?
Old Jan 16, 2007 | 10:14 AM
dzlfarmboy's Avatar
Question Tranny oil cooler removal for twins?
Just wonder what some of you all have done with a aftermarket cooler or just blocked it off and not have one, does it get to hot like sitting in traffic and stuff. Thanks
Old Jan 16, 2007 | 10:41 AM
John DiMartino's Avatar
I added aftermarket 40K cooler under the radiator,after a yr of using just the one out front.If you drive in any kind of traffic or slow speeds you need to add a coole,or relocate the stocker.If i had it to do over i would just move the stock one,and lenthen the heater hoses to it.The trans runs too cool here in NY winters until i get working it plowing.
Old Jan 16, 2007 | 10:58 AM
ratsun's Avatar
There has been lots of discussion on this topic ( some even started by me ) and I have done it on both my trucks. I could not keep check on the temps in traffic with the converters I had with out the factory heat exchanger. Also on cold days on the hwy with the converter locked the temps would be to cold. Here is a picture of mine relocated up under the rad support.
There is a pic of the other cooler in my photos
I run from the trans to the HE in the pic to a B&M 1.5x8x11 plate cooler in the place of the stock tube and fin cooler in front of the rad, then to a fan mounted 1.5x12x12 B&M plate cooler mounted under the box then back to the tranny. This is all plumbed with -10 single wire hyd hose for a little extra capacity . I have found this combo to be the most effective for how I use the truck. The bed cooler is mainly to aid in cool down at the track but I have found myself using it in heavy stop and go traffic. IMO spend the time relocating it and your tranny will be happier.
Old Jan 16, 2007 | 12:58 PM
mullady76's Avatar
I run a 16 pass Derale tranny cooler with fan under the bed in place of the heat exchanger. I drive in bumper to bumper traffic every day and the temps are not much higher then using the factory heat exchanger. I will add that I do not tow with this truck.
Old Jan 17, 2007 | 12:29 PM
dzlfarmboy's Avatar
Ok thanks for the replys guys.
Old Jan 17, 2007 | 06:28 PM
Jambbii's Avatar
I got mine to fit in the stock location with twins....
Old Jan 19, 2007 | 02:25 AM
joefarmer's Avatar
I did one setup like that and said "never again". It's so much easier to move it up front, it's cheaper and the lines are shorter/better.
brandon.
Tank_66
Jan 11, 2012 10:12 AM
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
