Throttle stumble with Quadzilla Adrenaline and/or Edge Comp Drag??
Old Jan 11, 2008 | 11:02 PM
  #31
dodgediesel's Avatar
All good now. Air in the lines, how, I don't know. Bled the lines and she slowly fired up. Still has an APPS stumble so I'm guessing that's a major surge issue I'm still seeing?
Old Jan 12, 2008 | 01:24 PM
  #32
I'm gonna try to clean up all the connections with some air and dielectric grease then try swaping out the AIT and the MAP sensor to see if that clears it up. I bought a APPS as a last resort to clear this stumble up, it was only $608.00!!!
Old Jan 15, 2008 | 11:22 AM
  #33
Replaced the APPS and throttle cable(It Broke) and now my throttle is too good. Boy is this throttle touchy!!! Any ideas on how to stiffen it up???
Old Jan 17, 2008 | 12:41 AM
  #34
I have no idea what's going on here with this truck of mine!!! I getting this bad shudder when I'm on the throttle with the Edge Comp Drag on. Turn the Drag off and it doesn't seem to be there. Remove the wire tap, turn the Drag on and there it is again. Hard runs and the fuel pressure drops from 13-0-2-0, etc... Changed out to the Adrenaline and the same results as the Edge Comp. I changed the APPS, MAP and AIT sensor and no luck, still there. I have to test the fuel pressure with another guage to see if I'm actually dropping to 0psi. This is just about driving me to selling this truck. I'm guessing it has to either be my new SO VP44 or the ECM if it's not a fuel problem??? WTH is going on!!!!
Old Jan 17, 2008 | 12:56 AM
  #35
1-5-3-6-2-4's Avatar
have to put a mechanical guage on it, no doubt, didn't know you don't have one. No isolator no nothing. straight fuel to guage. I'll lend you one of my guages and hose for testing you just need to get a fitting.
Old Jan 17, 2008 | 06:35 AM
  #36
J Lent's Avatar
Sounds like your Fass is cavitating or the return check valve is sticking open & not allowing it to build pressure. I would get that gauge on there right away. I've seen things happen like this & turned out to be the fuel pump relay was triggeriing on/off, other times it has been bad grounds on pump, chassis grounds etc. Is your fass running constantly without cutting out? Is your Fass ground & power hooked directly to the battery & triggered by a relay? Are you using a draw straw to pull fuel from the tank? When I installed my draw straw, my factory tube was rotted going into the tank & had a pin hole in it. This also can cause your symptoms, can be sucking air & this is why you are seeing pressure then 0, then pressure. etc. Just trying to help.
Old Jan 17, 2008 | 10:32 AM
  #37
I think it's a fuel thing too Jamie. I do have the upgraded draw straw from FASS. I put in a new FASS relay and the FASS is direct to the battery. You said something about the return spring?? I really have to get another manual gauge on there to double check this!! Thanks J...
Old Jan 20, 2008 | 04:32 AM
  #38
I've got a new from Cummins, return check for the VP if you want that too, I'll probably never use it.
Old Jan 20, 2008 | 07:22 AM
  #39
NoSeeUm's Avatar
Give this DTR Thread some thought.
Jim
Old Jan 20, 2008 | 12:25 PM
  #40
I might take ya up on that offer Demon???
Good post Jim, thanks...
Old Jan 20, 2008 | 12:27 PM
  #41
no prob. I have a small arsenal of parts that I may or maynot ever use
Old Jan 20, 2008 | 12:39 PM
  #42
Sweetttttttttt!!! Have you got your Adrenaline yet???
Old Jan 20, 2008 | 12:42 PM
  #43
yes I did just recently get it.....havn't got actually on the truck yet but she is here
Old Jan 20, 2008 | 01:05 PM
  #44
Let me know what you think!!
lvmknsmoke..
Nov 21, 2024 07:33 PM
thehighroad
Apr 8, 2011 01:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
rockjeep73
Mar 25, 2005 03:34 AM
