straight pipe
Old Dec 23, 2006 | 04:35 PM
dr.caterpillar's Avatar
straight pipe
i have a 94' reg. cab long bed 12v, with factory exhaust. i would like to straight pipe it without getting an entire turbo back system. any suggestions on what i will need?
Old Dec 23, 2006 | 05:04 PM
TIMMY22's Avatar
you could cut it off before or after the cat. from there go to an auto parts store and by a piece of strait 4" and some reducers etc. I would recomend using a tail pipe because you will get a droan in the cab if you don't.
Old Dec 23, 2006 | 05:36 PM
ccmckee's Avatar
If it's '94 you should have 3" pipe under there.Get a piece from a muffler shop and a couple of band clamps and gut everything out from the front of the cat to the back of the muffler.It will be loud, i put on a flow thru muffler after having a straight pipe for about 8 months.
Old Dec 23, 2006 | 07:00 PM
Forrest Nearing's Avatar
stock they go 3" off the turbo, 4" after the cat, then 3" after the muffler... we just run 3" from the downpipe to the tailpipe
Old Dec 23, 2006 | 08:19 PM
Racer9's Avatar
I ran 4" from the cat back. Straight pipe, 1-4" connector, 1-30* elbow. You'll have to measure, I forget how much. Just knock off the muffler, use the conector to put the 4" on the cat out pipe, run it back to the axle, put the elbow on it, and the extra pipe. It comes out at about the oem location. It clears everything, but is close to the spare tire. I welded on some hangers to support it, and ran it until I got the stacks.
Old Dec 30, 2006 | 09:30 PM
why isn't this thread locked?
Old Jan 2, 2007 | 10:53 AM
lgp9999's Avatar
A previous owner cut the muffler off of mine and installed straight pipe in its place. With just a cat, it sounds extremely nice, and not too loud either, IMO.
Old Jan 2, 2007 | 11:22 AM
woodrat's Avatar
mine has a straight pipe that ends a ways behind the cab. It has a downturned tip on it, which i'm told helps with the drone. It's not too bad at all. It came that way from the previous owner.
Why would this thread be locked??
Old Jan 2, 2007 | 01:46 PM
Dodge12vKing's Avatar
When I had my stock exhaust I went to the pipe and muffler shop and got it done for $60 in about 10 minutes.
Old Jan 2, 2007 | 06:49 PM
Brendan's Avatar
I don't beleive that the 94s had a cat, mine didn't. It should already have a 3" to 4" expander about 2 feet in front of the stock muffler, cut it off, move it as close to the turbo as possible and go with the above mentioned suggestions from there. Should be good!
Old Jan 2, 2007 | 09:32 PM
Katmandu's Avatar
Question
Why should it be locked ?
MTC
Jul 14, 2009 06:27 PM
Jordan5687
Feb 14, 2007 05:00 PM
yarddog
Aug 30, 2005 09:01 PM
PADZZ
Feb 9, 2003 08:33 AM
