stacking the edge comp
Old Nov 23, 2007 | 07:01 PM
powermad's Avatar
i was thinking about stacking my edge comp but i dont have the need or money for a smarty. does anyone have any knowledge on stacking a chip with the edge that will only cost a few houndred bucks but still give me around 50 more hp? or does anyone want to sell a smarty for a couple houndred... might as well ask
Old Nov 23, 2007 | 07:45 PM
J Lent's Avatar
A set of rv275 injectors are within budget.
Old Nov 23, 2007 | 09:08 PM
powermad's Avatar
yea im going to go with mach 4s when its time for injectors. how do you like the dragon flows? does the fluidamper make a diferance
Old Nov 23, 2007 | 09:39 PM
Ph4tty's Avatar
Get it made into a drag comp.
Old Nov 23, 2007 | 10:30 PM
J Lent's Avatar
I would never try another injector after trying my 4 flow Dragons. No smoke with the box turned off, unbelievable smooth idle & all the way up the powerband. The Fluidamper is a great mod, smoothed my engine down alot...very impressed with it. The Drag comp upgrade really makes a difference in these trucks, but only if you run the rpms up over 2700.
Old Nov 23, 2007 | 10:40 PM
bridleman's Avatar
Jlent what does the fluidamper actually do?? How much are they and would some one with my set up benefit from this??
Old Nov 23, 2007 | 11:04 PM
J Lent's Avatar
It was originally designed for high revving race engines to balance the rotating mass more evenly than stock balancers. The stock balancers have a pressed on ring around the outside with rubber between the ring & balancer body which at higher revs starts to dislodge. This causes the balancer to "wobble" which in turn is like a wheel on your car that popped one of the weights throwing it off balance. The smoother the mass rotates, the longer the engine will last. Fluidampers are a one piece body filled with fluid.
Old Nov 23, 2007 | 11:08 PM
J Lent's Avatar
I think they are around $375 or so, but I can't remember for some dumb reason. I looked under my hood when my engine was stock & noticed my stock balancer wobbling due to the thing coming apart. I would recommend them to anyone stock or otherwise, but I'm sure it isn't a "must have" item.
Old Nov 23, 2007 | 11:14 PM
bridleman's Avatar
Thanks J Lent
Old Nov 23, 2007 | 11:37 PM
powermad's Avatar
how much is the upgrade for the edge drag i do run it past 2700rpms infact i raced a mustang cobra and noticed i want more fuel past 2700. oh and i was neck and neck with the cobra! hehehe.
Old Nov 24, 2007 | 07:54 AM
J Lent's Avatar
$125. for Drag upgrade. It fuels to 3200rpm.
Old Nov 24, 2007 | 12:25 PM
one54ton's Avatar
you wont need to stack with a drag comp
Old Nov 24, 2007 | 02:51 PM
Big Blue24's Avatar
Send it in to edge, and a week later you'll have more revs. It does have an earlier bottom end as well. You can't do much better than a drag comp or a hot juice. The quad box is going to be a hot item when it gets released to the public.
Old Nov 24, 2007 | 04:39 PM
powermad's Avatar
wow sounds like a nice deal
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
