solid steel track bar
I installed the solid steel steering stabilizer and adjustable track bar over a year ago. my front end has been getting a little loose so i took it into the shop and i need a four ball joints and the bushing on the track bar. my question is does anyone know if oem bushings will fit on this track bar. I called Solid Steel but their voicemail is full.
Get a Lukes Link for the trac bar, permanent fix.
DSS will do no good without a new steering box.
If you had wander before DSS, the oem box is shot.
I've replaced practically the whole front end a few years ago, new bj, uj, lukes link on everything, dss, new steer box and its as straight as a train now. Zero wander.
make sure your at the right solidsteel website for the number http://www.solidsteel.biz/ other wise if you have the non adjustable track bar it is an 03 track bar. so I dont see why OEM bushings wouldnt fit. I cant beleave there warn. Thats a new one by me.
Don't know what the SS adjustables use for a bushing?? Probably would have bgt one of them, but they were not on the market when I upgraded mine.
RJ
If you're referring to my track bar, I wouldn't know. Over 50K miles, many of them high speed off road miles, and I haven't even had to tighten the spherical bearing, let alone replace it. But when I do, I can rebuild the joint for about $20, without taking it off the truck.
And if I chose to run a MAG pan, mine clears.....
If it soothes your offended sensitivities, Don's track bar won't clear the diff on stock ride height 2001+ 2nd gens. Don has referred many of these folks to Darin......
Derek Roch
May 20, 2010 11:54 AM
CTD2001
Aug 22, 2009 10:03 PM
horselady
22
Jan 10, 2008 11:24 PM
afoulk
Sep 6, 2007 11:23 PM
6 Shaker
Jan 18, 2006 06:00 PM
We really need a tongue-in-cheek type smilie somewhere here...
