Solid steel ind. track bar ?
Old May 19, 2010 | 10:13 PM
Derek Roch's Avatar
Hey guys i bought and installed the solid steel adjustable track bar for my 01 this past weekend and i was wondering what is the correct or most percise way to adjust and center the front axle? I eye balled it and it looks pretty close but i would like to make it as perfect as possible.
Old May 19, 2010 | 11:48 PM
nickg's Avatar
4ft straight edge laid against the tire (vertical) and the fender, on my truck it worked perfectly, straight edge touches fender and top and bottom of tire
I'm running 265-70-17 on 3rd gen rims.
or you can break out a tape measure and measure like points between frame and axel
Old May 20, 2010 | 11:54 AM
01RAMer's Avatar
Actually, if you didn't try to straighten the steering wheel yet, just adjust the track bar till the steering wheel is in the correct position and you'll be back to where you should be. If you already adjusted the steering wheel, then you going to have to do some measuring.
CTD2001
Aug 22, 2009 10:03 PM
horselady
22
Jan 10, 2008 11:24 PM
afoulk
Sep 6, 2007 11:23 PM
just_crankin_it
13
Jun 1, 2007 04:12 PM
6 Shaker
Jan 18, 2006 06:00 PM
