solid steel 3rd gen. adjustable track bar
Old Sep 5, 2007 | 05:45 PM
afoulk's Avatar
I installed one of these on my truck 2 or 3 weeks ago, but unfortunately the clunking thru my steering wheel. Had a buddy start the truck and work the wheel back and forth while I watched the front end. I noticed over 1/8" of movement (deflection) in the track bar bushings, which I'm pretty sure are polyurethane. I've rechecked the mounting hardware, and everything is still tight, torqued to their specs. Is this normal? I didn't think a poly bushing would move that much.
Old Sep 5, 2007 | 05:54 PM
smokindog's Avatar
Are you getting a weird vibration around 42-45mph and again around 70-72mph?
Old Sep 5, 2007 | 09:14 PM
afoulk's Avatar
no, no vibration. Just a clunk thru my steering wheel. I'm not saying that the trackbar has anything to do with that (rag joint in my steering shaft has a lot of play in it), but that much play in the bushings kinda concerned me.
Old Sep 5, 2007 | 09:29 PM
vzdude's Avatar
DTR's 'Go to Guy'
An 02 shouldn't have a rag joint. It should be a u-joint shaft. They are infamous for making noise too. Braking hard and accelerating hard feel it in the wheel and also quick, short turns in the wheel. Have a buddy reach under the hood and shake the steering shaft while you hold onto the wheel and see if it is the same "feel".
Old Sep 6, 2007 | 05:59 AM
afoulk's Avatar
It has like a rubber disk right below the upper u/joint....I assumed this was a rag joint.
Old Sep 6, 2007 | 06:28 AM
vzdude's Avatar
DTR's 'Go to Guy'
I can't remember right off hand, but I was pretty sure that the rag joint shafts had the pin box at the bottom and rag joint at top. If you have u-joints top and bottom, I can't think of what that rubber disc is!? Maybe......
Old Sep 6, 2007 | 06:10 PM
afoulk's Avatar
My buddy's 98 12v has the same set up as mine too, so I'm sure its something they put on them from the factory.
Old Sep 6, 2007 | 11:23 PM
XLR8R's Avatar
Didn't Dodge change to the U-joint in '03?
Derek Roch
May 20, 2010 11:54 AM
77machomopar
20
Dec 11, 2009 10:37 AM
CTD2001
Aug 22, 2009 10:03 PM
just_crankin_it
13
Jun 1, 2007 04:12 PM
6 Shaker
Jan 18, 2006 06:00 PM
