Smarty which software to install.
Old Apr 17, 2011 | 11:00 PM
1generationkid's Avatar
I just purchased a S-03 from a friend. I have a 01 H.O. 3500 6 speed to install it on. Which is the best software to download to the module and where can i find the software. i use the truck for towing. I am usually towing about 15,000-18,000lbs. Also which level would be best for towing this much weight.
Any info would be helpful.
Thanks
Old Apr 19, 2011 | 11:32 AM
DIESELWRKS's Avatar
no offense but you should search on the site here tons of smarty info, have you tried to look on smarty's website. the smarty downloader you have in hand should have the updated REVO software on it. if its older and does not you can download that from the smarty's website. if you have sub settings like torqu mang, timing, fuel duration then you have the REVO software. if you have a stock clutch and plan to tow heavy you want to be careful with the smarty and the timing. do a search , also www.madselectronics.com
Old Apr 20, 2011 | 01:43 PM
No offense taken, I was just on the Cummins Forum site and looked at some postings there. I just thought I would post the same question here. where is the smarty info posted on here.
thanks
Old Apr 20, 2011 | 01:46 PM
DIESELWRKS's Avatar
use the search tab and type in smarty and plan on alot of surfing through threads I would also look at smarty's website there is alot of good info on settings under questions or FAQ's can't remember
Bradleysram
19
May 12, 2009 08:36 AM
dodgediesel
Jan 1, 2009 09:46 PM
jeepme79
May 21, 2008 11:25 AM
dirt
Jan 22, 2008 10:13 PM
AlCorr
Jan 4, 2007 06:25 AM
