SBC DD vs. Con FE
Originally posted by Gear Poet
SB DD doesn't sound like the proper recipe for a truck with the NV5600 6spd (weakish syncros) that's used mostly for towing and around town. Thanks Rod, that's good information.
So they will have a single disk with better driving characteristics than a dual disk. Also easier on the syncro's
I've got a 13" Fe in front of my 5spd in my truck and it's a good clutch.
One thing you have to be ready for is it's either all in or all out. There is no slipping it to make backing or taking off in 2nd easier. It's not bad once you learn to drive it, but it does take some getting used to. Mine will shift pretty quick, and the more HP you put to it the better it shifts.
Like someone said above if you want a DD in a 5spd you gotta put down the almost $900 for the big input shaft on top of the $1300 for the clutch so it's not a cheap BOMB.
If you don't want to use the truck for Truck Pulls I'd go with the 13" Fe if you think you want to pull go with the DD.
DB
DB
dodgediesel4x4
May 8, 2005 08:21 PM
