RPM's
Old Mar 1, 2003 | 06:21 PM
dieselcrazy's Avatar
RPM's
when accelerating my rig seems to fall off soon after 2grand ( u know like im losing power ). is that because of the governor ?? and if so what advantages or differences are there between the 3 and 4k gov spring kits ?? also with the use of 1 of these kits ( lets say the 3k for now ) do u actually keep pulling all the way to 3k or do u still fall off? if u keep pulling i bet that turbo sounds awesome. is it ok to use one of these kits while still stock??<br> thanks guys,scott
Old Mar 1, 2003 | 07:03 PM
John_P's Avatar
Re:RPM's
Scott:<br><br>It sounds to me like your governor is working just<br>about like it should. When my truck was &quot;stock&quot;<br>it would pull a little past where yours does then<br>start &quot;falling off&quot; as you describe. This is just<br>the action of the pump/governor beginning to<br>shut fuel off to the engine as per the setting/<br>parameters of where the P7100 has been set.<br><br>I just changed from the 3K to 4K governor spring kit<br>and can tell you that the difference is very noticeable!<br>I have a automatic transmission. If I &quot;manually&quot; start<br>out in first gear and let the engine rev up it will go all<br>the way to 3800 RPM, I will then shift to second and<br>it will do the same thing and continue that action <br>until I get up to 4th gear (O.D.). By just putting<br>the truck in &quot;Drive&quot; and flooring it, the engine will<br>pull hard to about 3200-3300 RPM and then shift<br>into the next gear until it hits 4th gear (O.D.).<br><br>I have noticed that the 4K springs have really<br>helped my &quot;bottom end&quot; acceleration! I know I<br>am getting more fuel now because the smoke is<br>worse than it was before! Not that I mind that! ;D<br><br>Anyway, I hope this has helped you some!<br><br>-------<br>John_P
Old Mar 2, 2003 | 04:38 AM
VinDiesel's Avatar
Re:RPM's
[quote author=dieselcrazy link=board=7;threadid=11654;start=0#110622 date=1046564465]<br>do u actually keep pulling all the way to 3k or do u still fall off? if u keep pulling i bet that turbo sounds awesome. is it ok to use one of these kits while still stock??<br> [/quote]<br><br>Mine pulls strong to 3,000 and spins right on up to 3,200 with the 3K GSK. The 3K kit improves throttle response too (maybe not quite as much as the 4K). I don't know that the turbo sound will be predominately noticeable, it will be there, but the exhaust and engine sounds are most noticeable.<br><br>John P.-<br><br>Wow, I can only imagine what your manual shifts are like at 3,800!!! <br>I thought mine was launching pretty good when I go through the gears at 2,700-3,000.
Old Mar 2, 2003 | 09:45 AM
John_P's Avatar
Re:RPM's
Vin:<br><br>Yeah, the first time I did it &quot;manually&quot; I had that same<br>look on my face!! But,.....if you have ever watched<br>that old &quot;BD&quot; video of Piers doing his burnouts and &quot;donuts&quot;<br>with his old truck, and the tach &quot;pegged&quot; on 4,000 RPM<br>I guess mine will be O.K.!!<br><br>These Cummins 5.9 engines are just amazing to me! ;D<br><br>--------<br>John_P
Old Mar 2, 2003 | 10:00 AM
Re:RPM's
ok im convinced, u guys twisted my arm just to the breaking point ;D ;D ..after i get my gauges installed this is deffinately an upgrade i want to make. now how do i decide to go with the 3 or 4k kit and how difficult is it to install( are the instructions fairly clear ) thanks again guys, scott
Old Mar 2, 2003 | 04:00 PM
bryan5791's Avatar
Re:RPM's
springs? are yall refering to valve springs? is this a do it yourself project would it be benifical on a total stock truck
Old Mar 2, 2003 | 04:57 PM
VinDiesel's Avatar
Re:RPM's
Scott,
For me the decision to go with the 3K kit was based on several factors-
  • Not having to change the valve springs on the exhaust (I hear the rear two cylinders are somewhat difficult).
  • I felt uncomfortable with the idea of spinning such a heavy rotating mass much past the &quot;factory redline&quot; on the tach (but it seems other members have not found it to be a problem).
  • I didn't see any real benefit to the higher rpm since my auto was shifting at about 2500 WOT at the time.
(Interestingly, my full throttle shifts went up about 200 or so rpm when I put in the 370s. [More pressure from the TC, I think] Then I hear of shifts like John P described, and it makes me go Hmmm...)
Yes, the kit comes with a good set of instructions for going in through the side. I felt it was easier to go in through the top (under the fuel plate). In addition to the height measuring mentioned, you can also count the &quot;clicks&quot; of the retainer nuts. It doesn't take much to turn the nuts, though I now have a modified (notch in the middle) wide screwdriver tip just for this purpose.
Old Mar 2, 2003 | 05:06 PM
VinDiesel's Avatar
Re:RPM's
Bryan,<br><br>We're actually discussing both- with the 3,000 rpm governor spring kit, you don't have to change the exhaust valve springs. The 4,000 rpm kit includes the ex. springs so you don't float the valves at the higher rpm.
Old Mar 2, 2003 | 09:44 PM
BigBlue's Avatar
Re:RPM's
Valve floating is bad.
Old Mar 4, 2003 | 05:28 PM
John_P's Avatar
Re:RPM's
&quot;Vin&quot; is right, you need to have the 60lb. valve springs<br>for the 4K gov. spring kit. I already had installed those<br>when Scheid Diesel fixed my blown head gasket last<br>year! ;D <br><br>The 4K spring kit is great! As I said earlier, it has really<br>helped my bottom end and I have gained some top end<br>speed too!!! <br><br>-------<br>John_P
Old Mar 5, 2003 | 04:04 AM
VinDiesel's Avatar
Re:RPM's
Yeah, and did you notice that John P manually shifts at 3800 RPM!!!! ;D
Old Mar 5, 2003 | 06:38 AM
bulthisl's Avatar
Re:RPM's
[quote author=VinDiesel link=board=7;threadid=11654;start=0#110921 date=1046646409]<br>Bryan,<br><br>We're actually discussing both- with the 3,000 rpm governor spring kit, you don't have to change the exhaust valve springs. The 4,000 rpm kit includes the ex. springs so you don't float the valves at the higher rpm.<br>[/quote]<br><br>You have to replace the INTAKE AND EXHAUST valve springs with the 4k gov. kit.<br>If the ex valve would float the intake would also.<br>The only application requiring just the ex springs to be changed is the addition of a exhaust brake.<br><br> : Eddie : 8)
jefjsak
Jan 15, 2015 03:44 PM
53 willys
31
Jan 31, 2008 02:24 PM
skeeter
Jan 18, 2006 03:17 PM
dieselnewbie
Apr 13, 2004 12:00 AM
fishin fever
Feb 22, 2004 08:32 PM
