RemoteStart installed, where to tap the WTS ligh
Old Oct 10, 2007 | 07:39 AM
BIGBEN's Avatar
I have the system completely installed, except I don't think I have the wait to start wire tapped into the correct wire. It starts with the remote, but it doesn't wait for the wait to start light to go off.
I have it tapped in to the Orange/black wire on the center plug on the PCM. when I test with my meter. I get 12v when I turn the key forward but only for a second. and the light stays on for 3-20 seconds. Is there a better place to tap this? is this the correct wire. The Remote starter is a ProStart CT-3200.
Old Oct 11, 2007 | 10:07 AM
BIGBEN's Avatar
This must be a mystery wire? I put my multimeter on every wire I could find in the drivers foot well to see if I could fing the wire I'm looking for with no luck. any help would be great.
Old Oct 11, 2007 | 11:24 AM
Jfaulkner's Avatar
Muted User
I'm assuming the truck your referring to is the 2000 in your profile? If so it's the orange/black wire in the top black plug in the center of the firewall in the engine compartment. It is a negative pulse wire.
Any more ?'s ask away.
Old Oct 11, 2007 | 08:39 PM
AAmeeting's Avatar
He's right --> also
12volts red and pink/black + ignition harness
Starter yellow + ignition harness
Second Starter
Ignition dk. blue + ignition harness
Second Ignition
Third Ignition
Accessory black/orange + ignition harness
Second Accessory black/white + ignition harness
Keysense
Power Lock orange/purple 5wi driver door harness
Notes: Keyless models use positive trigger for lock, and 5-wire for unlock. Can also find wires at the central timer module to the right side of the steering column, lock is orange/green, unlock is pink/green.
Power Unlock pink/purple 5wi driver door harness
Lock Motor orange/black driver door harness
Unlock Motor pink/black driver door harness
Parking Lights+ black/yellow headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow - headlight switch or DKP
Notes: To avoid dome delay, use tan for the drivers door and black/lt. blue for the passenger door. Both wires are located at the central timer module to the right side of the steering column. Use both wires and diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm lt. green/orange - driver door harness
Notes: Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger through a 1.5K (1500) ohm resistor. MUST use relays.
Factory Alarm Disarm same wire
Disarm No Unlock
Tachometer black/gray ignition coil
Notes: Diesel tach wire is gray/black. The wire is located on the center of the firewall. There are two black plugs, the wire is in the top plug without the white insert. The tach wire can also be found at the ECM on the passenger side firewall in connector C-1, pin 8.
Wait to start orange/black - center of firewall, black plug
Notes: See DirectFax document 1090.
If using the orange/black for wait to start causes a shifting or cruise control problem then use a pulse timer relay instead. Refer to DirectFax 1091 for wiring information.
Brake Wire white/tan + brake pedal switch
Parking Brake
Horn Trigger black/red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
Old Oct 12, 2007 | 08:31 AM
cLAYH's Avatar
If you cann't find the wire check to see if your remote starter has a delay setting.
Mine doesn't sense the WTS light, it just delays starting by 20sec everytime its used.
Old Oct 12, 2007 | 09:06 AM
BIGBEN's Avatar
Thanks guys for the help. I am going to see if I can get to the bottom of this today. I have to wait to get my Altinator back from being rebuilt. it took a cr@p yesterday. but I just got the call from the shop it will be ready today.
Again thanks very helpful
Old Oct 12, 2007 | 03:29 PM
Sea:\>Drive's Avatar
When I did mine I was worried about those statements of "if using the WTS light causes trouble" so I just set mine to a 30-sec delay (which is the longest the WTS light stays on in my neck of the woods). Some times in the summer I wish it would start faster, but I've gotten used to the 30-second delay now.
Old Oct 15, 2007 | 07:27 PM
AAmeeting's Avatar
You should use a diode.
Old Nov 21, 2007 | 05:26 PM
SCC's Avatar
SCC
What remote start system did you guys decide on??? I am looking to do one in the near future.
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
alto22
34
Feb 16, 2007 09:28 PM
Hoss
Apr 11, 2006 11:37 PM
bgilbert
Mar 2, 2006 04:01 PM
