Quad Adrenaline Beta Testing....
The Adrenaline is a very impressive box. The control that it has over both timing and fuel allows it to be capable of making a lot of hp over a very wide power band. It spools faster then anything else I have tried. I haven't dyno'd it yet, but I did make a 1/4 mile pass. Even with the non-comp verison of the beta software, it ran about the same as I do with my drag comp.
Paul
Got a weird issue going on in that has happened serveral times now. Basically out of no where the truck cuts out. Its not a surge but more like a stumble. It happens on all power levels except level 1 best I can tell. It totally related to this box as I have the TST inline in the off position and it doesn't do it with the TST. It also does it without the TST installed. Very weird and I'd like to see if anyone else is having the same issue.
EDIT:... Found an expected Release date of 12/15!!!
Well had my first problem today out of the new file. The TT would not shut off my truck like i have have prior to this file and it was working great until i shut down the truck and 30 min. later walk out to still hear my truck running and brake or gas pedal wouldnt kill it. So not sure if anyone else has had this problem with the new file or not because i know quad said he had the TT worked out. SO might just be a freak thing i have killed the truck 5 times after the screw up and everything seems ok again.
My TT only works sometimes as well, and the brake or throttle will not kill the truck. I rechecked all my connections even the pump tap everything seems in order, and I still don't seem to get as much power out of this tune.
Joe
Joe
Buy...or just test drive a Smarty!
The 'stock' setting on the Smarty has all the latest updates and appears to leave the TQ Mgmt out.... even after returning to the stock setting!
(just like it leaves the 'High Idle' mod installed)
Did for me anyway.
RJ
(just like it leaves the 'High Idle' mod installed)Did for me anyway.
RJ
