Quad Adrenaline Beta Testing....
Old Dec 3, 2007 | 11:25 PM
  #151
bucket truck's Avatar
Hey guys, is the Adrenaline for sale to the public now?
Old Dec 3, 2007 | 11:38 PM
  #152
Haulin Mutt's Avatar
I finally put the V300 tune in. I have not tapped the wire yet so I am only in the two lower settings. Even in PL02, is this tune milder? I don't see much difference between PL00 and PL02. When I had the tune in it that came with the box, PL02 seemed snappier. I am not expecting a rocket though with my gearing and tire size. The timer works for the 20 seconds every time, but neither the brake or accelerator turn it off.
Old Dec 4, 2007 | 12:19 PM
  #153
lotero's Avatar
well i will by dynoing my drag comp and then my quadzilla this weekend, i believe quad is working on it but the comp file doesnt work on my truck for some reason, so what file should or what files are you guys dynoing on?
Old Dec 4, 2007 | 12:34 PM
  #154
RowJ's Avatar
Beta V300. As stated somewhere around here...I picked up 25 HP over previous stack (Smarty/TST Comp).
Originally Posted by MikeD
Dynos are nice, but give me 1/4 times any day.
Mike, I had one run at track. Results are not conclusive for three reasons...
-Still had Smarty on #2, for tire correction.
-Adrenaline on #10... not fastest setting
-Because of Smarty, still have boost building problems since going to Mach 6's.
But results were encouraging (13.1/101).... as good as last several runs on TST Comp Stack.... and this Quad box is still a long way from max setup.
Have since removed Smarty and boost building problem is eliminated totally.
RJ
Old Dec 4, 2007 | 12:37 PM
  #155
merrillr4's Avatar
It is amazing how the same program works differently on some trucks. The TT works everytime for me. I can shut it off early by touching the brake.
Old Dec 4, 2007 | 01:03 PM
  #156
xtoyz17's Avatar
Quad,
Clear your inbox!
Old Dec 4, 2007 | 01:13 PM
  #157
lotero's Avatar
thanks.. i am currently running the old factory 6 setting because the beta v300 wont work on my truck and of all the files that seems to be the strongest. so you dynoed with a defueling file?
Old Dec 4, 2007 | 01:30 PM
  #158
RowJ's Avatar
No defueling on BetaV300. Everything turned off except TT, as per Quads last E-mail.
RJ
Old Dec 4, 2007 | 02:07 PM
  #159
lotero's Avatar
ahh thats right, my mistake.
Old Dec 4, 2007 | 04:49 PM
  #160
dodgediesel's Avatar
I'm still having surging issues with Beta V300 at low rpm and around 1700rpm-1900rpm. I wonder if it has anything to do with it being -25 here. My truck hates the cold with these Mach 4's!!! Everything else is working 100%. Boy that high idle would be nice at these temps!!!
Old Dec 4, 2007 | 05:21 PM
  #161
lotero's Avatar
guess you will have to trade me for my DDs.. they work great in the cold!
Old Dec 4, 2007 | 06:58 PM
  #162
Luis, how cold is it where you live right now? I see you are going to dyno! Do you have any numbers with your old chip or stack to compare?
Old Dec 4, 2007 | 08:30 PM
  #163
lotero's Avatar
it ranges from 20 or so at night to a really high high of 50 today. normally about 40ish degrees.. my drag comp dynoed at 534/1231
Old Dec 4, 2007 | 08:37 PM
  #164
Excited to see your Adrenaline Numbers. Quad got you any HP tunes to play with?
Old Dec 4, 2007 | 08:47 PM
  #165
BBA's Avatar
BBA
hey quad when do you think that we will have anymore tunes to play with? Im really wishing I had the high idle again and longer TT. Not trying to harras you or anythin just wondering.
