Quad Adrenaline Beta Testing....
Old Dec 16, 2007 | 08:58 AM
  #301
J Lent's Avatar
Originally Posted by hink
Not sure I'm followin ya there. You mean use the end of the screwdriver where the bit would go and tap it over the top of the screw?? Kinda like a socket, kinda sorta??
Yepper, worked for me. Then I bought new torx bolts from the hardware store to make my life easier.
Old Dec 16, 2007 | 09:01 AM
  #302
J Lent's Avatar
Originally Posted by Big Blue24
I also have a big line kit with a stretched spring so my pressure stays up fine. My Juice used to tell me I had 15-16 psi at idle at the IP, Adrenaline tells me that I have 16-17 psi at idle at the IP.
My gauge is maybe a pound off from my mechanical, but what I don't like is the readings at wot. It jumps around from 7-9-2-5-4-10, but my mechanical is steady at 7psi.
Old Dec 16, 2007 | 03:47 PM
  #303
DieselUnlimited's Avatar
I was wandering what RPM some of you guys were seeing compared to the Edge Drag Comp and Redline?
Old Dec 16, 2007 | 04:17 PM
  #304
J Lent's Avatar
Its been wet all week & today it has snowed. Haven't been able to get that high yet....let you know as soon as it dries out.
Old Dec 16, 2007 | 04:46 PM
  #305
RowJ's Avatar
Your getting a little ahead of us. We're still beta testing 'street' model, as I understand it.
But I can tell you it pulls hard to 3500 rpm!
RJ
Old Dec 16, 2007 | 05:21 PM
  #306
hink's Avatar
Gotcha!! I'll try that this week. Thanks!! BTW, for the most part my fuel press. reading on the Adrenaline is pretty solid, it has freaked out 1 time since I hooked it up yesterday. It did the same thing you described, hasn't done it since. I went out today bustin drifts and playin in the snow, even in PL02 it feels pretty responsive and smooth, just a slight surging around 4psi boost @1700-1800 rpm, nothing like the XZT+ did when I had it on the truck. So far so good, can't wait to get the pump tapped.
Old Dec 16, 2007 | 07:25 PM
  #307
J Lent's Avatar
I paid more attention to my fuel pressure gauge today & I am getting the psi difference. At times it was 2 psi lower than my mechanical gauge reading, but most of the time right on or 1 lbs. less. It is really sensitive....may need some adjusting. I noticed that the truck is idleing smoother now....maybe the ecm is finally getting to know the new software or something.
Old Dec 16, 2007 | 09:36 PM
  #308
voyles's Avatar
When shutting my truck off It would almost shut down before TT would engage, then idle back up. Today I turned the key off slowly, click, click & it didn't almost shut off....nice smooth steady idle till 3 minutes past. It only does it when I shut down too fast.
I have similar problems. It would drop down to like 200 rpm's and kick back up. Sounds really hard on the engine.
The boost gauge is about 3 psi off and doesn't seem to be as responsive as the mech gauges.
But this box does rip. Just waiting for the snow to dry up some before pounding it.
I have been letting Justin know about all these small issues.
Old Dec 16, 2007 | 11:06 PM
  #309
J Lent's Avatar
You still running a stock clutch voyles? That box is gonna kill it.
Old Dec 17, 2007 | 09:46 PM
  #310
dodgediesel's Avatar
Pretty quiet on here lately???
Old Dec 17, 2007 | 09:49 PM
  #311
BBA's Avatar
BBA
I was thinking the same thing but im really thinking its becuase everyone is out seeing how good this box really does huh? lol. IM just waiting on some new tunes to go play with and hope they get some good ones before i get to dyno. Im hopin for a 500hp run.
Old Dec 17, 2007 | 10:03 PM
  #312
Big Blue24's Avatar
BBA, are you gonna try to hit 500 with your stock turbo and the water/meth? You have your head studded yet? HO vp44 or SO?
Old Dec 17, 2007 | 10:15 PM
  #313
bnold's Avatar
drove 440miles with the box today... No real changes from my initial review of the V300..
I did test my high idle box with this box.. set my high idle to 1200RPMs and ran through all power levels with no change in idle whatsoever...
Old Dec 17, 2007 | 10:54 PM
  #314
J Lent's Avatar
I'm going on a 120 mile pull tomorrow morning hauling my 15k# trailer deep in the heart of W.V. I'll let you guys know what this box has tomorrow night.
Old Dec 17, 2007 | 11:00 PM
  #315
Bnold, so far just myself and J Lent has this crazy idle issue?? I'm just waiting for a fix!!!
