Pulling truck
Old Jan 20, 2004 | 12:18 AM
OhioRam's Avatar
Pulling truck
What is the best way to go around creating a pulling truck, another words should I start looking for a 12 valve or a 24 valve?? Which one will put out the most power in the long run?? I have my eye on a 94 ctd 4x4 with a 5 speed is this a good starting point?? I appreciate your help.
Old Jan 20, 2004 | 10:25 AM
dodgeman01's Avatar
You can build the 94 but you would need a different pump. the 160 pump is kinda small and has a few problems when getting into the higher HP ranges.
DM01
mcevins's Avatar
OhioRam,
A 12 valve Cummins is probably the best way to go for a pulling truck. It has a P-7100 mechanical injection pump and can be tuned to do more than a 24 valve. On the 1994 cummins you will have a 160 pump and most will tell you that a 215 pump is where you should begin. These pumps can have governer springs installed to rev to 4000 rpm's and even more. Cam plates, delivery valves, governor springs, afc springs, and injectors seem to be a much less expensive way to gain serious HP and torque than the upgrades on a 24 valve although 24 valves can be made pretty wicked. If you are serious about pulling, I would contact Enterprise Engine, Scheid Diesel, Haisley Machine, or Piers Diesel Research for information for pulling. These guys know pretty much everything there is to know about pulling. Also go to Thunder in Muncie on June 5th and 6th and see what truck pulling, drag racing, and dynoing is all about!!
Hope this helps,
Meacham Evins
Old Jan 20, 2004 | 12:43 PM
MoreSmoke's Avatar
Seriously talk to Enterprise! Doug is very nice, super helpful and will get you on the right track.
Old Jan 20, 2004 | 01:34 PM
dsljunkie's Avatar
Building a pulling truck is easy. Follow these steps:
1. Quit school
2.Get High paying job
3.Buy a van and live in it down by the river
4 Continue living in that van down by the river for a solid year.
5. Take the money you made and buy 2 of everything you can get your hands on.
6.Walk everywhere because the pulling truck and your van will always be broke .
Seriously though a 12 valve with about 700 ponies would be the way to go. But dont mess around and try to just get by, you will have to buy the best of EVERYTHING. Other wise youll end up going back and fixin' it anyways.
Good luck and happy spending,
Scott
Old Jan 20, 2004 | 03:33 PM
OhioRam's Avatar
Thanks For your help guys. I really appreciate it, I Have learned more about diesels on this site than i would have ever learned anywhere else.
Old Jan 21, 2004 | 10:17 AM
dodgeman01's Avatar
Hey Ohioram where are you located?
DM01
Old Jan 21, 2004 | 10:35 PM
OhioRam's Avatar
Medina County
CRYSTALCRYSTAL
Jun 4, 2008 05:23 PM
mullercarl
Competition / Pulls / OffRoad
45
Mar 19, 2007 10:10 AM
gdh11
Apr 7, 2004 01:18 PM
dodgeboy59td
29
May 5, 2003 05:16 PM
