pulling and egts
Old Mar 14, 2007 | 08:09 PM
12vstrokethis's Avatar
pulling and egts
hey i have a 97 5-speed 4x4 315-75-16 with 370 100 plate 3gsk hx35/40 18cm2 exhaust housing 3" straight pipe. and i am planing on pulling a travel trailer and i am thinking the egts are going to get to hot. i am thinking of 4" all the way back and 16 cm2 exhaust housing but i dont know any advise. to lower the egts
Old Mar 14, 2007 | 08:16 PM
BCSCUMMINS's Avatar
How big is the travel trailer?
Old Mar 14, 2007 | 09:15 PM
kbailey's Avatar
A 4" downpipe and exhaust will make a big difference. A HTT or ATS exhaust manifold will also help. Water methanol is also a good way to go but that only works until you run out of water.
Old Mar 15, 2007 | 06:41 PM
well i have not got a travel trailer yet but i am thinking 27" or smaller bumper pull
Old Mar 15, 2007 | 11:35 PM
BCSCUMMINS's Avatar
Go ahead and do the 4in. but far as the turbo goes I think you will be OK. If you are thinking about water methanol I would stick to strait water or washer fluid. I’m not convinced that the ats or the htt manifolds do anything if the head is not ported and polished.
Old Mar 16, 2007 | 03:00 AM
TheBigNasty's Avatar
Don't waste your money on the housing or the manifold. An exhaust will be the best bet but still nothing major. You have a decent amount of fuel and will pull it fine but you will have to watch that pyro. Only safe bet would be to get a bigger turbo.
Old Mar 16, 2007 | 07:47 AM
cumminsdriver635's Avatar
Advance the timing to 16* or so. It should be plenty manageable, just watch the pyro.
Eric
Old Mar 16, 2007 | 11:04 AM
Oh I agree it will pull it no problems but he will have to watch the pyro. I was meaning out of any upgrade the turbo would be the best bet.
Old Mar 16, 2007 | 11:59 AM
Ph4tty's Avatar
Well if your looking to do an exhaust and want to keep your turbo, a megamouth downpipe from the dtr store should make a bigger difference in egt
Old Mar 17, 2007 | 03:05 PM
TxDiesel007's Avatar
I agree with this..
Also dont forget to time the truck as well 16-17 degrees will work great, better fuel mileage, slightly cooler EGTS, and a more effecient powerband for ur GSK... The turbo will be the best way to go, but a megamouth downpipe can be a good temp fix for high EGTS, better than a five inch exhaust with a stock mouth...
Rick
Old Mar 20, 2007 | 11:37 AM
74dart's Avatar
What boost pressure are you running?
archer39
Sep 14, 2009 05:25 PM
mullercarl
Competition / Pulls / OffRoad
45
Mar 19, 2007 10:10 AM
lightening ram
May 10, 2006 12:50 AM
gunracer1
Dec 13, 2004 02:52 AM
doug
103
Jul 2, 2003 02:27 PM
