Programmer info
Old Nov 4, 2013 | 08:50 AM
bigcrunch's Avatar
Programmer info
My complete stock (except for the DNJ governor in the trans) 1999 Dodge 3500 Cummins auto trans 4.10 gear 4x4 needs a little extra power to pull my old boat ( approx 9000lbs) up hills\mountains. The truck has 56k miles on it I have owned it since new.
I'd like to just do a programmer, what is the most popular brand used? I'd prefer to not cut wires but as I was informed to adjust timming on the pump they require it. Also keep the stock trans\torque converter alive it will be upgraded in the future.
thanks for the help have been a lurker of this site now I need a little input.
Old Nov 4, 2013 | 10:09 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
In your case the Smarty JR would be perfect...no wires to cut, simply plug it in and let it download.....
Give me a call at the Performance Shop and I can go into details....
Lowest Pricing allowed with warranty and free shipping for DTR Members
Old Nov 7, 2013 | 06:22 AM
DIESELWRKS's Avatar
I'm sure Top meant SMARTY S-03 as we in the vp-44 dont get as cool of stuff as the CR crowd. I can say smarty is quick easy to use and has alot of easy levels and sublevels to choose without destroying your very low mileage 99.
if there is a smarty Vendor near you most of them will allow you to go to them and then they can do a demo download on your truck to see if you like it. if you like it then you can get ahold of Top at the store here and he can save you some $clams.
Old Nov 7, 2013 | 07:19 AM
bigcrunch's Avatar
The SMARTY S-03 has 10 power levels, what is CaTCHER software?
Use additional Timing for towing?
thanks,,,,
Old Nov 10, 2013 | 11:17 PM
DIESELWRKS's Avatar
sorry was off for a few days.
but go on www.madselectronics.com look under products and check out the FAQ sheet.
CaTCHER software's inside
Ten different performance levels
Fastest download in the industry, a typical ECM update takes less
than two minutes
ABS tire height updates in just seconds
Not traceable in the stock setting. Smarty leaves no footprint
Cold weather 3 Cylinder High Idle is enabled in all softwares
Reads Diagnostic Trouble Codes in plain text
No tools required, no fuses to pull
USB built in for simple updates
Most complete keyboard in the industry
Reliable, it works off your OEM hardware
Programmable Speed Limiter from 25 to 250 mph (in trucks of 2001 and
2002 the speed limiter is programmable in mph, older trucks have only a speed adjustment)
and
SW# 1 : Fuel Saver
SW# 2 : Only more fuel and Boost fooling
SW# 3 : Like # 2 + added timing
SW# 4 : “Soft” CaTCHER no added timing
SW# 5 : Like # 4 + added Timing
SW# 6 : Mild CaTCHER no added timing
SW# 7 : Like # 6 + added Timing
SW# 8 : CaTCHER no added timing
SW # 9 : CaTCHER with Timing
Software number Zero,
About half the power of a stock software. Use it whenever reduced power is desired or
when you have to make sure that NO SMOKE is produced .
Software number One,
The Fuel Saver software. Mpg gains vary, in most cases a + 2 MPG has been reported.
Please notice that the timing in this software is rather aggressive.
HEAVY TOWING is not recommended with this software.
Software number Two,
This software increases the fuel delivered by the ECM and does the boost fooling.
Software number :Three,
Same as software # 2 but timing has been added.
CaTCHER softwares from number : Four to number Nine,
The even numbered softwares are identical to the odd numbered ones, except for the
timing. The softwares without added timing are intended for use with timing adding
boxes.
The power gain at top RPM with these softwares is almost identical. These softwares
differ greatly in HOW they get there. Than higher the software number then more
aggressive the throttle response from idle speed up. Aggressive to the point that the
softwares Eight and Nine can become difficult to handle on slippery roads. Please be
very careful when you use these softwares for the first time! It takes some time to learn
how to handle them.
Old Jan 28, 2014 | 06:47 PM
cstewart's Avatar
FYI: Smarty!!
Stroked-Z
20
Dec 5, 2011 07:01 PM
Pa outlaw
Aug 25, 2010 10:32 PM
tboling
Apr 9, 2007 09:04 PM
zzsdad
57
Nov 30, 2004 09:23 AM
