post-turbo pyro temps
Old Mar 29, 2007 | 10:38 PM
smknram's Avatar
My pyro is mounted after the turbo (done by previous owner) until i get it changed to pre-turbo, which is on my list of things to do, what is a safe temp and a max temp for it being after the turbo on the truck in my sig?
Old Mar 29, 2007 | 10:43 PM
99globalwarmer's Avatar
something like 1000* i dont recall do a search it should show up
Old Mar 29, 2007 | 10:50 PM
smknram's Avatar
thank you global
Old Mar 29, 2007 | 11:22 PM
DL1221's Avatar
Some specs, look here:
http://dodgeram.org/tech/dsl/Facts/96specs.html
Old Mar 29, 2007 | 11:27 PM
Homestead's Avatar
I ran pre and post pyros for awhile and it can be an eye opener when it comes to difference in temps.
You can say that 900-950 post turbo is safe. There is about a 300 degree drop thru the turbo. BUT, when your hammering on it, I have seen 500 degree differences between pre and post so use your head when pulling hills or beating on it.
Lower temps during steady highway cruising, idling, and lower power situations, temps can be about the same pre or post, but start pushing it or adding fuel to the mix and they climb at different rates.
Be careful
Jeff
Old Mar 30, 2007 | 12:25 AM
NoSeeUm's Avatar
Be careful
Jeff
From my experience with pre and post EGT, Jeff's advice is 100% spot on.
Jim
Old Mar 30, 2007 | 01:06 AM
smknram's Avatar
thanks guys, what is the best method of choice when drilling the manifold, i have heard of a couple different ways
Old Mar 30, 2007 | 02:31 AM
BCSCUMMINS's Avatar
a drill bit maybe
Old Mar 30, 2007 | 10:15 AM
smknram's Avatar
to keep metal shavings out of the manifold? i should have been more specific bcs
Old Mar 30, 2007 | 10:23 AM
infidel's Avatar
I've drilled/tapped dozens and do nothing special at all with no problems, the shavings will blow right out the tailpipe the first time you start it.
I just can't understand the paranoia people have that makes them think they have to use grease and magnets or even remove the turbo. Only thing I can figure is they think they're working on the air intake side of the turbo rather than the exhaust side.
Old Mar 30, 2007 | 11:23 AM
dodgediesel's Avatar
I run both pre and post, 950 post turbo = 1250 pre turbo...
rockittboy
May 26, 2006 02:02 AM
DmaxEter
Mar 11, 2006 05:03 AM
by2005
May 23, 2005 04:49 PM
cLAYH
Aug 2, 2003 08:09 AM
redram
Dec 10, 2002 09:54 AM
