pac-brake engagement delay
Old Dec 26, 2009 | 01:59 AM
Jammie Dodger's Avatar
probably moisture in the air lines , however it takes about one hour of driving before my pac-brake works.
any ideas?
thanks
Old Dec 26, 2009 | 12:00 PM
SWC's Avatar
SWC
Which Pacbrake do you have? If it is the older style that uses vacuum, I would check that the air inlet on the controller solenoid is good. Moisture should not get into the line but "things" happen. If it is the PRXB someone else can help.
Stan
Old Dec 26, 2009 | 12:12 PM
Stan
thanks
the truck is "new to me" and so is the pac-brake, i be believe it's the PRXB type, but i'm not completely sure, there is an air compressor and tank with air lines.
edit, it maybe this model as i a have 4" exhaust and a hx35 turbo.
Old Dec 26, 2009 | 02:02 PM
BlueDually's Avatar
Mine do the same, dump a cup of air brake antifreeze (methanol) in the air tank. It will coat all the lines and take care of the freezing.
Old Dec 26, 2009 | 02:56 PM
thanks BD
sounds aboot right, will try the methanol [same solution for air brake lines], very, very plausible!
cheers
Jammie
Old Dec 29, 2009 | 08:01 PM
problem gone.
engage the pac-brake switch at the beginning of the trip for a couple of minutes and hay-ho the pac-brake is working, no delay.
:happy:
Old Dec 30, 2009 | 01:05 AM
BlueDually's Avatar
Awesome
Mexstan
Jan 5, 2015 12:23 PM
Shilohman
22
Nov 19, 2009 05:13 PM
iflych52
25
Oct 10, 2006 09:25 PM
wvcowhauler
13
Apr 3, 2005 11:39 PM
