pac-brake engagement delay
probably moisture in the air lines [duhhh], however it takes about one hour of driving before my pac-brake works.
any ideas? thanks [guitar] |
Which Pacbrake do you have? If it is the older style that uses vacuum, I would check that the air inlet on the controller solenoid is good. Moisture should not get into the line but "things" happen. If it is the PRXB someone else can help.
Stan |
Originally Posted by SWC
(Post 2663227)
Stan the truck is "new to me" and so is the pac-brake, i be believe it's the PRXB type, but i'm not completely sure, there is an air compressor and tank with air lines. edit, it maybe this model as i a have 4" exhaust and a hx35 turbo. |
Mine do the same, dump a cup of air brake antifreeze (methanol) in the air tank. It will coat all the lines and take care of the freezing.
Originally Posted by BlueDually
(Post 2663265)
sounds aboot right, will try the methanol [same solution for air brake lines], very, very plausible! cheers Jammie [coffee] |
problem gone.
engage the pac-brake switch at the beginning of the trip for a couple of minutes and hay-ho the pac-brake is working, no delay. :happy: |
[guitar] Awesome
