P7100 Conversion Kit
Old Sep 19, 2006 | 07:09 PM
cummnz4x4pwr's Avatar
On the 2000 trucks, is it still using a vaccum style cruise system? Mine all electronic. The p pumping a 24v seems to be more finicky and requires tuning for the style of driving you drive. The earlier truck seem to be easier to convert over the P pump. The truck newer than 2001 seems to have more electronics and issues with the P pump.
The three trucks we've p-pumped have been My '00 5spd My Dads '02 auto and a customers '01 5spd cruise works on all but mine now because Ive been experimenting wth new throttle setups and and gov. springs and the apps gets in the way.
They all have been tuned the exact same way.
Jake
Old Sep 19, 2006 | 07:55 PM
Tiger Rag's Avatar
Originally Posted by 24valvepuller
you can also just pull the gear off the cam and leave the cam in there, that is how we did mine
You didn't swap the cam to drive a mechanical lift pump? Nevermind, I see where you are running a FASS.
Old Sep 20, 2006 | 01:24 AM
Ph4tty's Avatar
Haisley has a kit for your truck. Its pricey. They told me that their puller truck use pumps that flow from 900cc to 1200cc of fuel.
Any idea how much a vp44 flows for comparison's sake?
Old Sep 21, 2006 | 10:49 AM
Mike Holmen's Avatar
The Guru
Jake, you ran the TPS on the injection pump right? How did the 02 auto truck work after installing the P pump. You the first one that has done a 02 auto and said that it works. Haisley, PDR and DTT has told me that this is a difficult swap and most guys that have done this have sold their trucks afterwards just cause your constantly tweaking the pump to get everything to work right.
Old Sep 21, 2006 | 05:12 PM
the throttle is a lttle tight but other than that it works great, Cruise and all.
My dad pulls his three car hauler with it about 1000 miles a week. the only complaint he has is that the throttle is a little to tight.
Jake
Old Sep 21, 2006 | 09:02 PM
Just got back from My Dads Place and took a look under the hood and it does have the vacuum booster for the cruise under the drivers side battery.... it has a mfg. date of 10-01 but it is an 2002 on thee title... not real sure when they started the all electronic cruise....guess im gonna have to investigate that further.
Jake
Mike what is the mfg. date on your truck?
mx yfz 450
35
Feb 8, 2010 10:53 PM
JDGPULLER
Sep 15, 2006 05:24 PM
storx
22
May 27, 2006 09:53 PM
ccowboy
Nov 7, 2005 08:30 PM
clarkoh
Aug 15, 2005 03:04 PM
