P7100 Conversion Kit
Old Sep 15, 2006 | 09:07 AM
storx's Avatar
Its been a while since i been on here due to being in the field from the military. I was wandering who all sells the kits for this and also what is included in the kits. I called Schieds one day and spoke to a lady and she couldnt tell me what was in them so im still clueless.
Old Sep 15, 2006 | 02:33 PM
Mike Holmen's Avatar
The Guru
Haisley has a kit for your truck. Its pricey. They told me that their puller truck use pumps that flow from 900cc to 1200cc of fuel. You tranny computer might hate your P pump. I don't know if your computer needs the TPS sensor for shifting. You might have to get a plate adapter made up for your tach to work. The tach sensor is under the VP.
Old Sep 15, 2006 | 05:12 PM
cummnz4x4pwr's Avatar
Exclamation
his 2000 has the crank sensor so he would not need the cam sensor adapter plate.
He would also just attach the stock tps to the side of the p-pump and use it as his throttle linkage this is what we have done with the 3 trucks that we've p-pumped in the past.
Haisleys kit includes
Front timing case
pump mounting brackets
new oil supply fitting and T fitting for the block
injector lines
I believe this is all but ill give Patty a call mon. to make sure.
Jake
Old Sep 15, 2006 | 05:25 PM
You or anyone else that is interested can give me a call about the conversion. I have performed three of the conversions and can put you in contact with the owners if need be.
Jake Staton
325-998-0267
325-200-8847
Old Sep 15, 2006 | 05:34 PM
kelownadiesel's Avatar
Thanks for the offer jake,I am contemplating a p pump here soon too.It will be on a 5 spd,so no tps right?I dont care about cruise either.Any advice would be helpful
Old Sep 16, 2006 | 07:20 PM
The Guru
So what did you do for the cruise control?
Old Sep 17, 2006 | 10:51 AM
I welded 3 3/4" spacers on the back of the apps, so it would bolt up to the p7100 and then did a little work to the linkage to get everthing to clear and work without sticking.
Jake
Old Sep 17, 2006 | 12:52 PM
qwest's Avatar
"Front Timing Case" Do you have to pull cam to change this?
Is any maching required?
Old Sep 17, 2006 | 02:35 PM
yes
and no machining
Old Sep 18, 2006 | 04:13 PM
qwest's Avatar
Thanks,
Would an old Mech rotary bolt up to a 24v cover????
Old Sep 18, 2006 | 05:03 PM
Thanks,
couldnt tell ya, youd just have to experiment with that one.
Jake
Old Sep 18, 2006 | 09:11 PM
24valvepuller's Avatar
you can also just pull the gear off the cam and leave the cam in there, that is how we did mine
Old Sep 18, 2006 | 09:57 PM
Rods's Avatar
how many CCs r u guys pushing on the P pumps and r they street friendly with a light foot
Old Sep 19, 2006 | 07:47 AM
with smaller DV's and injectors and the factory GSK , it was very street friendly. I had a surging problem at 50 mph while grossing 26000 lbs, but I lost a hx-40, a bearing, and the freeze plug on the back side of the cam, as well as 2.5 gallon of oil and never finished the trip. When we rebuilt it we changed alot of stuff and I've only driven it about 7 miles all year, so I never got a chance to get it right
Old Sep 19, 2006 | 12:17 PM
The Guru
On the 2000 trucks, is it still using a vaccum style cruise system? Mine all electronic. The p pumping a 24v seems to be more finicky and requires tuning for the style of driving you drive. The earlier truck seem to be easier to convert over the P pump. The truck newer than 2001 seems to have more electronics and issues with the P pump.
