p - pump conversion questions
Old May 2, 2009 | 06:45 PM
  #226
John_P's Avatar
Originally Posted by rhino 660
Scheid now has the injection lines listed for 500-600 $$ what happened to 378$$
Rhino 660:
Scheid Diesel makes two different sized aftermarket injector lines, those being, .093 and .120. Could you have possibly been looking at the .120's
for that price??
John_P
Old May 2, 2009 | 09:11 PM
  #227
Tate's Avatar
Originally Posted by John_P
Rhino 660:
for that price??
John_P
They also have stock and .084" diameter lines, in both carbon and stainless steel.
Old May 3, 2009 | 09:37 AM
  #228
John_P's Avatar
Rhino:
I see what you mean now. I got on Scheid Website last night and saw the pricing you posted. But in looking at the picture, they include some stuff with the kit you may no need. I would give Gary Stroud a call at Scheid Diesel (Terre Haute) @ 1-800-669-1593 and see what the cost is of JUST the sized lines you want in the carbon steel as Tate suggested.
Hope that helps you some.
BTW,.....as Tate mentioned, stock lines are .078. Aftermarket lines start at .084, then go to .093 then up to .120 if that has not changed. FWIW,......I did not care for the .120 lines on my 96' as they "surged" bad at idle. So, I went with the smaller .093 lines and they have worked very well for me.
John_P
Old May 3, 2009 | 11:47 AM
  #229
rhino 660's Avatar
if im looking for 600hp then what lines would be best suited for me
Old May 4, 2009 | 08:33 AM
  #230
John_P's Avatar
Rhino:
On my 1996, I was able to hit the 600 mark with the .093 lines. In fact, the way my truck was set up at that time, the .120's actually hurt my H.P. some.
My guess is that my turbos were a little too small to take care of that extra fuel. FWIW,.....I never tried the .084 lines.
Old May 5, 2009 | 10:53 AM
  #231
rollincoal02's Avatar
i made over 600hp with .084 lines and i am WAY overfueled, i have fuel there for quite a bit more power, but lack the air to burn it.
stock sized .078 lines would not have a problem breaking 600hp as long as the pump/turbo was properly tuned.
Old May 10, 2009 | 10:47 AM
  #232
rhino 660's Avatar
sounds good i will get the .84's im gathering the parts right now working on a deal for the p-pump gear case brackets throttle cable throttle linkage and oil line as we speak
after i get that i will buy the lines
also im getting a 160 p-pump what should i do to it to put out 600 hp worth of fuel i would like to do it myself im thinking 3000 gsk mack plug 100 plate
then not sure that half ton in diesel power had a 160 p-pump and did 700hp and they said they never took it off the truck what do you think
Old May 10, 2009 | 10:48 AM
  #233
rhino 660's Avatar
maby i should try 550hp with the small twins i have
jimbo486
May 8, 2016 06:07 PM
rightwinger
Apr 16, 2013 08:55 PM
6 2 Carl
Nov 27, 2010 09:55 AM
wcialrlter
Apr 17, 2008 05:51 PM
TexasHardcore
Aug 29, 2004 12:20 AM
