Options...?
Old Jun 16, 2007 | 11:17 AM
CODODGE2500MAN's Avatar
Options...?
So my VP44 is waving bye bye to me, so what should I replace it with? I'm planning on runing what I have in my sig. plus mild injectors and maybe a bigger turbo. WHat should I get?
Thanks for your help!
Old Jun 16, 2007 | 11:28 AM
Found this....are these prices any good?
Is this what I should replace it with or is there a BOMB version of the vp44 (other than ATS's hp one for over 2000.00?)
Old Jun 16, 2007 | 11:59 AM
Big Blue24's Avatar
Do a search on HRVP, you will have all the info you need, and after reading for a day, you will put in a newly rebuilt stock output... SO VP44 for 1200 bucks and make more power when you go wild, idle smoother, and last just as long.
Old Jun 16, 2007 | 12:26 PM
THanks!
Any suggestions on where to get it? Best price?
Old Jun 17, 2007 | 10:03 AM
Old Jun 17, 2007 | 10:14 AM
RowJ's Avatar
I'm not a big fan of the HRVP! Too much unadjustable smoke for my liking. All VP-44's are now rebuilts! I would check around your area for prices from Auto Service Centers. They are out there in the $1,000 - 1,100 range.
RJ
Old Jun 17, 2007 | 11:14 PM
Ph4tty's Avatar
Injectors can add as much extra fuel as a hot pump or even more so lots of guys will recommend the direct replacement so vp44. The hot rod pumps have a reputation for a lopey idle too.
With that said I run a hot rod vp from Industrial Injection and with mach 4's I make as much power as guys with mach 6's on so pumps (with no fueling box) so I'm pretty happy with it except for the lope. When I get a run with the tst I'll find out if I can still hang
Jbolt001
Nov 27, 2002 01:31 PM
j
15
Nov 21, 2002 09:56 PM
Extreme Diesel
Nov 11, 2002 12:05 PM
misterKTM
Nov 3, 2002 06:51 PM
Vaughn MacKenzie
Nov 3, 2002 07:22 AM
