now can I go smaller
Old Oct 20, 2005 | 05:48 PM
mooseman's Avatar
After adding water/meth egts are more controllable. I would like to change the htb2 a little by going from a 14exh. to a 12 for quicker spool. The 14 spools quick now but a 12 would spool even quicker for my auto.
HTT won't have 12's in for about a month so I have a while to decide unless I find someone to trade with sooner.
What do you all think?
Thanks Mooseman
Old Oct 20, 2005 | 07:20 PM
Gotlift01's Avatar
Well granted it would spool much quicker, but then you might run into your egt problem like you did before, especially with the Mach 4's and the Drag COMP........... How much did the meth setup cool you down?? I guess that would be good to know.......
~Nick
Old Oct 20, 2005 | 07:53 PM
mooseman's Avatar
So far Ive dropped my max egts by 200 and 325 on a dyno run.
Mooseman
Old Oct 21, 2005 | 07:45 AM
Txwelder's Avatar
Will a HX35 12cm housing fit your turbo? Id trade if they will swap.
Old Oct 21, 2005 | 01:00 PM
zukgod1's Avatar
I have a HTB2 with a 12 and have been concidering swaping to a 14, maybe we should talk.
We are even both in Utah
Dan
Old Oct 21, 2005 | 02:47 PM
farmer dave's Avatar
I can see the wheels turning on this deal and it looks good for both.
Old Oct 21, 2005 | 03:35 PM
Gotlift01's Avatar
I can smell the smoke from the brains working to hard!!!! Just kidding. That would be a cool trade if it benefited both you guys!!!
~Nick
Old Oct 21, 2005 | 03:41 PM
zukgod1's Avatar
~Nick
Yes it would, HTT gives a good deal on a housing swap but the cost of gas to meet and swap housings sounds better for sure.
Dan
Old Oct 22, 2005 | 10:12 AM
RowJ's Avatar
MOOSEMAN
Your talking about the trade off between better daily driving vs better top end. That's your choice. But I bet you can peg your EGT gauge with the 14cm2 housing when Drag comp is on 5x5.....even with the Injection system. I know I can with my Mach 4's.
Unless your done with drag racing and playing hard, your not going to be able to control EGT's with a 12 cm2 housing at WOT. Since you just spent time & money to try and control EGT's, I don't get taking a step backwards?
Having just gone from a 12 cm2 to a 14 cm2 housing myself, I know they take some getting use to.
If you came from the small housing of a stock HY-35, I'm sure it was a BIG difference, but I would give yourself 1-2 months to "learn" to drive the 14 you have. It's the best housing for your set up! And the Mach 4's make it easier with their low smoke at light throttle.
Tips that work for me - Keep OD off till 60-65 mph. It's only 2400 rpm +/- @ 65 mph...the 5 and 6 speeds go there all the time. When heavy or starting up on hills I manually shift into 2nd till 35 mph....makes a big difference. Driving with higher RPM's is the key. It won't hurt the engine or MPG....like I said, manual trannies go there all the time.
Learn to ease into the throttle till Boost comes up...becomes second nature after a while.
Just my opinion.
RJ
Old Oct 22, 2005 | 10:59 PM
zukgod1's Avatar
Crap RJ now youve got me thinking that I otta stick with the 12 for a bit, with 38" tires and 3.55 gears the bottom end sucks already, with a 14 I may be stuck smoking in the middle of the intersection hmm.
Well mooseman drop me a PM maybe we can discuss this a bit.
Dan
sallyman1
15
Apr 1, 2009 10:05 AM
Journier
Nov 22, 2004 02:56 PM
jlells01
Oct 7, 2004 12:37 PM
fearghail
Mar 27, 2004 09:46 PM
Stamey
Dec 29, 2002 10:18 AM
