Next turbo
Next turbo
i am looking for a cheap turbo to upgrade from my hx 35, i was thinking of a 3rd gen turbo, is anyone running one on a second gen?
oh and do i need to modify the intercooler tube/boots?
Thanks!!
Thanks!!
Im not sure about the 3rd gen turbo.
But, what kinda boost you seein with your HX-35 currently?
You could do a HX-35/40 hybrid. Cheap and cost efficient. Builds a solid 45 lbs. Little more if you have the fueling for it. Coarse head studs is a good choice if your playin around 45 lbs of boost.
Have considered twins ? Solves alot of problems, will deliver you plenty of air, spool up is better, towing is great. You will need to o-ring the head and add a good exhaust manifold, and fuel plate. You seem to have everything else already.
Used HX40 can be found for 4-$500 you will need a diff downpipe though
I just done upgrading my turbo to the 3rd gen he351. I am still tweaking it but at the higher rpm's it seems to cool very good. If I can get up to cruising speed of about 70 and hit an incline it will not go above 1200 deg. Mid range it run a little warmer. I am only in the whole mod maby 350-400$. So i think it was a good mod. Big blue has some good write ups on the mod do a search. I am still trying to tweak the waist gate also so I can get more boost. I can only get about 28psi right now. This high elevation kills yea.
Young guns check these out. Might give you some answeres on the hybrid idea..
http://htturbo.com/cu.htm
http://www.gillettdiesel.com/HXUpgra...0mm8blade.aspx
Gillett is local to me and Ive gone to them many dif times for lots of things and they do real good work.
Tell em Ian Dyksman sent ya if you talk to em,
HTT is a good name brand as well, but IMO tend to be more $ for everything.
Hope this helps,
Ian
Hope this helps,
Ian
i went to gillet when i bought my pickup and it seemed kinda exspencive, i like toxic down in st. george, fabian is awesome! but any way i have considered twins, i made my own hx 35 backing plate that i can use. other than that i havent fabricated much. still trying to get funds together....
2broke2smoke
19
Aug 21, 2007 12:34 PM
MikeThomas
May 27, 2007 02:00 PM
Common
Sep 14, 2006 05:44 PM
mytrucksaslug
Dec 29, 2005 12:30 AM
hialtitude
Nov 6, 2004 06:54 AM
