Sponsored by:
Sponsored by: CARiD
anybody heard of moving turbo next to tailpipe?
Old Dec 24, 2005 | 11:53 AM
mytrucksaslug's Avatar
I saw this on some sat. morning car show. I think they said some japanese car company was starting to put the turbo next to the tailpipe. There were also a few of the guys the hotrod the little import cars that had done it. They said it dramatically lowered the temp. of the turbo since it was out in the open air instead of under the hood. Has anyone here ever done or heard of it being done? What might the pros and cons be?
Old Dec 24, 2005 | 12:32 PM
dodgezilla04's Avatar
closer to the collector of the manifold the better, exhaust energy is what drives the turbine. Energy is flow velocity and heat. A turbo will run for many many miles given enough clean, cool oil without any high temp shutdowns. No need to move it away unless space is a factor
Old Dec 24, 2005 | 01:05 PM
IA_James's Avatar
Seems like those living in the rust belt would be begging for something bad to happen to your oil lines too, having to run that far underneath the vehicle. Kinda puts me in mind of the rear A/C set ups on Suburbans, how they get the leaks and such from the lines under the vehicle.
Old Dec 24, 2005 | 01:37 PM
infidel's Avatar
Not real familiar with gasser turbos but aren't a lot of them powered by an electric motor where exhaust pressure and heat don't matter?
Old Dec 24, 2005 | 01:43 PM
Copenhagenjunkie's Avatar
I saw this on 2 guy's garage a long time ago, I think it was on a newer camero, the turbo was by the rear tires. That's all I can remember.
Old Dec 24, 2005 | 01:57 PM
Andy505's Avatar
gassers have much higher etg's than diesels do.....maybe that is why they're talkin'
I wouldn't think it would be a good idea anyway....you get less power from your exhaust and then your turbo has to pump that air back up to your engine. wouldn't be as effiecent.
Old Dec 24, 2005 | 03:00 PM
hotdram's Avatar
Check out these guys STS Turbos
~Rob
Old Dec 24, 2005 | 03:47 PM
Sidewinder's Avatar
Almost got me to post something till I saw who wrote this!
Old Dec 24, 2005 | 06:40 PM
Timmay2's Avatar
Remote mounting turbos is usually only for space issues. Where you cant fit a turbo, and cant route the intake/exhaust/intercooler tubing.
Not only that, but it doesnt require tearing apart the engine. easier to "bolt on" so to speak.. no special exhaust manifold needed, no extra heat shielding underhood, no tearing your engine half apart to replace the manifold, etc.
Old Dec 25, 2005 | 06:48 PM
thumper 549's Avatar
Just so no one calls anyone silly.....to date there has never been a electric turbo that comes close to working it would take at least a 25 HP motor to do it..........the stuff you see advertized on Ebay etc is a scam.......do the math/cant work
Old Dec 27, 2005 | 11:30 AM
cheff's Avatar
~Rob
I was just going to post about these guys. My buddy got one for his gasser Tundra. It works for sure, how long it will last I dont know. But it sure woke up that gasser engine.
Old Dec 27, 2005 | 01:41 PM
newriverSpecon's Avatar
Ram 1500 Hemi Double Cab, Standard Cab - A LOT MSRP
Performance Results
Boost: 7 psi
Rear Wheel Horsepower: 417
%'d increase: 59%
Rear Wheel Torque: 460
%'d increase: 62%
For that price we can buy twins and a box of choice and have 150 horse and nearly three times the torque. And still be able to afford stoolbucks.
Randy
Old Dec 27, 2005 | 08:59 PM
Maybe I'll just leave things the way cummins built it. Well - most things. LOL
Old Dec 28, 2005 | 10:15 PM
drew03's Avatar
that would create some seriouse turbo Laaaaaaaaaaaaaaag.
Old Dec 29, 2005 | 12:30 AM
Badfish740's Avatar
A while ago I saw that exact setup (turbo right before the muffler) on a turboed V8 Camaro (maybe www.thirdgen.org ?), the pics have to be on the net somewhere. From what I read lag wasn't as big an issue as they thought it would be and EGTs were pretty low. I think that proper sizing has a lot to do with it though.
M1Lover
Sep 24, 2009 09:41 PM
whinesnrattles
Apr 6, 2009 07:12 PM
doodah
May 30, 2003 06:33 AM
zeik
Mar 12, 2003 07:54 PM
