next mod to be done?
Old Dec 2, 2008 | 02:39 PM
97dodgeram2500's Avatar
alright so im bout to get my new trans in and i was wondering what i should do next. i already have boost and pyro gauges and a fuel plate. so what should be done next? 3 gsk, injectors, dv's, turbo, or what? im kinda tight on money so i figured the turbo will have to wait what should go in next?
Old Dec 2, 2008 | 03:00 PM
mcoleman's Avatar
If the KDP is tabbed I would go with the 3000gsk and or get it timed to 16 degrees next.
Old Dec 2, 2008 | 07:14 PM
97 D-Tec's Avatar
get rid of the stock exhaust elbow add the hx-40 style down pipe with a pdr adapter.. that way when you start running more fuel like injectors your egts will stay down. If you dont change it (although for most upgraded turbos you have to change to this style anyway) you end up with a massive amout of restriction because that elbow is only about 2 inches around...the next thing id do after that is add at least a intake manifold.. the injectors, and turbo depend on what you want to do with the truck
Old Dec 2, 2008 | 07:17 PM
clm12valve's Avatar
where do u get one of those elbows
Old Dec 2, 2008 | 07:44 PM
97 D-Tec's Avatar
where do you get what elbow?
Old Dec 2, 2008 | 07:55 PM
clm12valve's Avatar
r u talkin about the downpipe or the elbow before it
Old Dec 2, 2008 | 07:56 PM
clm12valve's Avatar
oh so your sayin no elbow at all didnt read close enough
Old Dec 2, 2008 | 09:17 PM
thoscos's Avatar
97dodgeram2500,
3GSK will ad a lot of fun for not much $.
On my truck I removed the muffler and punched a 3 inch hole through the combs in the cat. That will help free up the exhaust without making the exhaust note much louder, only deeper.
Timing can also be upped without spending a bunch of $.
Old Dec 3, 2008 | 06:35 AM
97 D-Tec's Avatar
yea when you convert it to a hx-40 downpipe it gets rid of the stock elbow which means you end up with a full 4inch down pipe not a 2inch into 4inch down pipe
6.7L MegaCab
30
Nov 10, 2011 10:36 PM
pwrtripls1
Jun 6, 2010 10:26 AM
jmccart
Dec 19, 2007 12:49 AM
mainer
Oct 23, 2007 02:42 PM
Ramdriver15
Jan 24, 2007 09:33 AM
