new turbo and boost elbow
Old Nov 1, 2005 | 09:10 PM
rebal's Avatar
Question new turbo and boost elbow
ok guys this is the combo 01 HO mad ecm mach 1.6s,AFE strait pipe .I am waitting for my new Hybrid hx35/40-w14cm . it will have a 60/86 comp.wheel and a high perf.w14cm housing it will be replacing the hx35. what is your opinion on this set up will it keep EGTs under control DO I NEED THE BOOST ELBOW or will the preset WG be good ??? will I need a 4" exhaust?
this is my tow rig(23k-26K gcvwr)
I need to get all the mods done by dec. and want the EGT issue put to rest.
thanks . Rebal
Old Nov 1, 2005 | 09:55 PM
MCummings's Avatar
Install the turbo on your truck,, the factory WG should be fine, but if you need more boost get the boost elbow, otherwise, you can modify the WG to run less boost.
4" Exhaust,, good idea. Do it.
What is your current boost level at WOT?
Us knowing your current situation will help us tune your future setup...
Merrick
Old Nov 1, 2005 | 11:56 PM
rebal's Avatar
so far 38 psi 1250 egt and climbing with whx35 and boost elbow
Hdog
Oct 27, 2014 10:52 AM
97dodgeram2500
Nov 1, 2009 11:51 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
