muffler delete ?
Old Jan 19, 2015 | 06:10 PM
caper's Avatar
muffler delete ?
Who was the company making the delete pipe for the stock 94-02 exaust systems I cant seem to find it on the net anymore , ??
Old Jan 20, 2015 | 12:26 AM
93-p-pumper's Avatar
Just get a piece of 3" pipe with a flare on each end that a few inches longer then the chunk of crap you cut out slip it onto both pieces of pipe and clamp it on.
Old Jan 20, 2015 | 01:46 PM
KATOOM's Avatar
Your local muffler shop should be able to do the job for $50.
Old Jan 20, 2015 | 05:03 PM
caper's Avatar
Not that simple , I believe it has an offset in the pipe and no one around here has a 3 inch bender and one end is bigger than 3 inch isn't it ? I think 3.5 inches ???
Old Jan 20, 2015 | 05:39 PM
KATOOM's Avatar
Down pipe diameter to resonator is 3". Section between resonator to muffler is 4". Muffler out to tailpipe is 3". Just cut out the resonator and muffler and fill the gap with a 3" section. Easy peasy.
Old Jan 20, 2015 | 07:01 PM
A straight piece of pipe will work. Been there done that a few times.
Old Jan 20, 2015 | 09:58 PM
caper's Avatar
Oh ok , I think the pipe I was looking at on line left the resonator in place , I guess I'll just cut the whole works out .
Old Jan 20, 2015 | 10:15 PM
KATOOM's Avatar
You "can" leave the resonator in place but yes, that means having to find a reducer in order to go from the larger resonator outlet diameter down to the 3" tailpipe diameter. Your muffler shop may have that reducer too.
I bring this up because there is an advantage to leaving the resonator in place. All the restriction is in the muffler but given the open flow-through design of the resonator, it doesn't harm anything to leave it in place other than its not going to allow your exhaust be the loudest. You may appreciate leaving the resonator in place too as it will reduce the typical straight pipe drone noise down to very little.
Old Jan 21, 2015 | 07:18 PM
caper's Avatar
cut the whole works out today and put straight piece in with a little offset near tail pipe connection $ 80 bucks and I drove away . sounds great around town when grabin gears , highway trips are gona be different now gona have to turn up radio .A bit louder and some drone only really notice it on the highway ,
Old Jan 21, 2015 | 09:16 PM
KATOOM's Avatar
Remember what I said about the exhaust pipe acting like a guitar string..... I know the picture is podunk redneck looking but this is what I did to my old straight piped stock 3" exhaust just to see if adding metal would do anything to reduce the drone. Results are that it considerably reduced the drone on my truck. Still loud out the pipe but absolutely more tolerable drone than it was without. And also, adding more metal and/or in different locations or longer lengths would help and change the note of the reverberation.
Old Jan 22, 2015 | 07:45 AM
patdaly's Avatar
LOL, best alternate use of a fence post yet!
Redneck? Nah........ what is it Marines say, "Adapt and overcome"?
Old Jan 22, 2015 | 08:19 AM
jrs_dodge_diesel's Avatar
That is known as a tuned mass damper. Basically, if you change the mass of an object, you change its resonant frequency. By adding the fence post, it adds more mass, and shifts the frequency range at which it will resonate.
It's fairly easy to accomplish too, if you have a droning problem as pictured above. Just add weights to the pipe until it stops. Angle iron would work too.
Old Jan 22, 2015 | 09:24 AM
KATOOM's Avatar
Exactly.....
Old Jan 22, 2015 | 05:45 PM
gorms's Avatar
I learn something here almost every day...
king cotton
Nov 24, 2010 10:33 PM
6.7megamax
22
Dec 9, 2008 07:09 PM
Red3quarter
Nov 8, 2008 04:11 PM
RobV2500
14
Oct 5, 2008 11:41 AM
CalypsoCowboy
Aug 20, 2008 07:11 PM
