More smoke?
Old May 3, 2008 | 10:43 AM
sleblanc386's Avatar
More smoke?
looking for a budget friendly way to get some more smoke out of the stacks? mods in sig
Old May 3, 2008 | 10:45 AM
Dwitt0187's Avatar
on a 2nd gen performance injectors are fairly cheap and will make her smoke like no other
Old May 3, 2008 | 11:11 AM
1BAD4X4's Avatar
Yup. Injectors is what you need. I was a little iffy when I read the title of this, but was glad to see you've done the other nessecary mods to lay the foundation for injectors.
Old May 3, 2008 | 02:08 PM
hink's Avatar
Try the Dyno tune for the Adrenaline on Quads website, see if that satisifies your need for smoke.
Old May 4, 2008 | 04:51 PM
What should i look into for a set of injectors? I know there are different spry patters and such??
Old May 4, 2008 | 05:23 PM
Philabuster's Avatar
Buy injectors once. It's not economical to spend money on cheap injectors and then upgrade later. Don M's Machs or DDPs are highly recommended by the members here.
Old May 4, 2008 | 06:21 PM
1BAD4X4's Avatar
Edge Jammer injectors are known for being some of the more smokier injectors... BUT they are also known for being some of the more hotter injectors as well, so be careful if you get them. Just be sure to watch your EGTs and don't stay on the pedal for too long. Once you get a larger turbo if that is in the plan for future mods, that will help cool them down. The price on the Jammers is of the more economical side, especially if you go with just the nozzles and not the whole injectors.
Mach or DDP injectors are cleaner injectors but in many peoples opinions a better injector. These two brands also have more powerful injectors availible then Edge or BD. Mach or DDP injectors are not so ecoconomically friendly.
I have Jammer 5s(Edge's most powerful injector) because I wanted a more smokier injector... but I was aware of the negative aspects of the Jammer series of injectors and what I need to do to rememdy them.
Old May 12, 2008 | 04:47 PM
Jturs's Avatar
couldnt he wire in a smoke switch? thats if he jsut wants to play with the smokem, obviously wont be any sort of power gain but i hear they are fun.
Old May 12, 2008 | 04:58 PM
bullboy85's Avatar
id do the injectors, jammers will be the cheap way to go but watch ur egts. do u do any towing?
Old May 12, 2008 | 10:18 PM
Bjans's Avatar
Throw in a set of industrial injection 3 flows. They are awesome injectors for the price and will be good with your stock turbo and with an aftermarket turbo in the future.
Old May 12, 2008 | 10:33 PM
Destination's Avatar
if you want alot of smoke try some bully dog step 8's
TDRattler
Jul 12, 2008 07:42 PM
BlackSheep5
Nov 27, 2006 07:52 PM
jbs007
Jul 8, 2003 01:29 AM
97CTD
Mar 17, 2003 08:14 PM
