more smoke with monitor unplged=more power?
Old Jul 12, 2008 | 08:04 AM
TDRattler's Avatar
I have a 03 ho with atriple dog with monitor. The pyro gauge was messed up so I had send it along with the monitor back to get fixed. All I did was unplug the 2 plug under the hood and left everthing else hooked up. I did throw a low boost and a over boost code. I could clear the over boost with the down loader but not the low boost code. The truck smoked way more with the monitor unplged. Am I getting more power that way or just wasting fuel? just wondering why it smokes more and what the codes mean. I also do have a boost elbow. Sorry this is so long just trying to give all info.
Old Jul 12, 2008 | 08:43 AM
sallyman1's Avatar
dont feel so bad. when i put my truck on stock 0 setting i still get smoke.
Old Jul 12, 2008 | 10:42 AM
D45's Avatar
D45
If you are talking about the Outlook monitor, I have heard you lose power with it......I bought one a sold it fast when I found this out.
I think I read it was a 30 HP loss,.........
Old Jul 12, 2008 | 03:42 PM
TDRattler's Avatar
Yes its the out look. But why the codes why is power differt with and with out it plugged in
Old Jul 12, 2008 | 07:42 PM
chrleb1's Avatar
The triple dog doesn't load in 3 programs to switch between. It loads in a single program with triggers. This is a common trick done on early ford cars to switch between tunes with a switch. Anyways, the moniter acts as a switch to change the position of the program. So if the moniter is sending the wrong info to the ECM, you will have not the correct HP.
nitis
Feb 26, 2007 07:38 PM
BlackSheep5
Nov 27, 2006 07:52 PM
RamRat
Mar 24, 2006 07:24 PM
dieselobsessed
19
Dec 16, 2004 04:21 PM
