more boost?
Old Nov 10, 2009 | 05:29 PM
Schneider's Avatar
more boost?
so i was wondering if i get 3k or 4k governor springs would i get more boost?
Old Nov 10, 2009 | 05:32 PM
Smokin96_12v's Avatar
do you have a boost gauge?
Old Nov 10, 2009 | 05:37 PM
Schneider's Avatar
ya i do.... y
Old Nov 10, 2009 | 05:49 PM
it would make the engine rev higher but that has nothing to do with how the turbo boosts, thats what I have been told at least. maybe someone can suggest a way to get some more boost without the springs, or why not both!!
Old Nov 10, 2009 | 06:01 PM
Schneider's Avatar
ya i just didnt know cause i knew it would fuel longer and give it more power
Old Nov 10, 2009 | 06:39 PM
G1625S's Avatar
There is no argument that the gov. springs are the way to go. You'll have a brand new truck to love, guaranteed! Assuming you're running the stock turbo, I would have to guess that your setup is more than enough to put the boost gauge into orbit. Anything over 35-40psi on an hx35 is wasted effort, anyway.
Old Nov 10, 2009 | 07:10 PM
Schneider's Avatar
ya well i was thinking about getting a bigger turbo but thanks for the advice.
Old Nov 11, 2009 | 12:28 AM
hey g1625s, what springs would you recommend?
Old Nov 11, 2009 | 08:11 AM
G1625S's Avatar
I have the DDP 3/4k kit and I'm very happy with them. Depending on what pump you have and what springs from the kit you use, dictates weather you get 3k or 4k. This way, if the 4k is too touchy for you, you can swap to the 3k w/out dropping more coin on another kit. Pretty neat, I think. Beyond that, any of the reputable vendors will have good quality springs available.
Old Nov 11, 2009 | 06:27 PM
recklesskelly's Avatar
doubt you would get any more boost since a stock fuel plate is defueling you by 2400rpms anyway. however an aftermarket fuel plate, a boost elbow and a 3 or 4 gsk will make it a totally different truck. Do a search for these things, days and days of reading here.
Old Nov 11, 2009 | 08:15 PM
thanks for the info G1625S, I think I am going to have to check into that DDP kit...
Old Nov 11, 2009 | 09:10 PM
Schneider's Avatar
so how much boost should i be pushing with my pump turned up and 100 horse injectors
Old Nov 11, 2009 | 09:23 PM
stock wastegate begins to open at a little over 19#s and is fully open at 23 so very little if any more than that. But 100 hp injectors and a boost elbow closed off will push your hx35 far beyond its efficiency range. 35 pounds is about the max you want to see with that turbo
G1625S
May 14, 2012 10:31 AM
JyRO
Jan 20, 2006 09:28 AM
j
Dec 21, 2003 10:26 AM
Commatoze
Nov 20, 2003 06:06 PM
