LUK Clutch and ATS 3 piece Help needed asap
First I have an almost new ( I mean really new you can still see the milling marks where the disk runs) LUK clutch disk, Pressure plate, and Flywheel. I am not sure if the Flywheel is LUK but its as new as the clutch. I also have the Adapter and its off a 97. I was wondering if you guys could give me a ball park as to what this would be worth? Im not selling it right now, I just would like to know what I should ask for it.
Second How does the ATS 3 piece manifold rate? Is it any better then the BD or the HTT?
Thank you.
Thank you.
I don't know how the ATS 3 piece compares but I bought one as a replacement for a cracked OEM one and was happy with it. Be sure to re-torque after it has run a bit if you get it. I had a couple loosen from the turbo.
Some mentioned that the castings were a bit rough inside but I didn't notice a problem with mine.
When I was shopping for clutches the I could get the Luk cermametallic (latest and greatest) for less than $600 shipped so I'm guessing that thing is just worth a few hundred. Luk makes the clutches in newer dodges so that might just be a stock replacement =\
As far as the manifold goes- there really hasn't been much whoop to do about any particular one, but I'd definately get one thats assembled and it'd be nice if it were tapped for the pyro too =P
I just put the ats 3 pc manifold on my truck the casting wasn't rough inside and it came pre-assembled and tapped for the pyro I got mine from ebay $300 shipped to my door.
Better watch Ebay closer.. I picked up a new HTT from someone for $305 last week.. It wasn't a dealer.. just someone selling spare parts.. No gaskets or bolts...
But than again.. I haven't seen the manifold either....
Bryan
Bryan
cbrahs
02-10-2014 07:54 AM
Death Dealer
02-22-2008 03:58 PM
